Carbotech Performance Brakes...
Old May 11, 2008 | 01:48 PM
CarbotechDanny's Avatar
CarbotechDanny is infamous around these parts
Hello 6speed members,
My name is Danny Puskar and I am from Carbotech Performance Brakes. Carbotech has recently become a sponsor on 6speedonline.com. I have been a member and a fan of this forum for quite a while now, and would love nothing more than to support this forum when possible.
If you’re not familiar with Carbotech then here is some information that separates us from everybody else. If you want more information then please visit our website at www.ctbrakes.com
Carbotech Performance Brakes™ began 15 years ago. In the beginning we thought like everybody else and made brake compounds out of carbon & iron. The problem with carbon & iron is that when it heats up it forms carbide. Carbide is used in cutting tools, so imagine what that does to your rotors.
Along with the fact that those compounds tear up rotors, they also produce very corrosive brake dust. While our competition stills uses carbon & iron as the main ingredients in their compounds, Carbotech™ started an entire new philosophy over seven years ago.
Carbotech Performance Brakes™, a world leader in Ceramic friction materials™. It was over seven years ago that Carbotech™ started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech™ is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use.
Carbotech-Ceramic™ compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech™brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry.
Our competitor’s brake pads perform like an “on/off” switch. Brake pads that perform like an "on/off" switch are upsetting the balance of the car by violently throwing all that weight forward (not to mention that you don't get any modulation with an "on/off" type of brake pad). You don't realize how much it upsets your car until you have tried Carbotech™ brake pads.
Carbotech™ has a seven year head start on the competition when it comes to our great philosophy on modulation & release, rotor friendliness, non-corrosive dust, and an unmatched consistent bite/torque control.
Carbotech™ uses advanced friction technology to perfect all of our compounds for the street & track. Research & Development (R&D) is not just a company philosophy; it’s a way of life at Carbotech. We strive in constantly improving our existing compounds as new technologies and materials come to market.
Carbotech Performance Brakes™ allows drivers to Go Deep™ into the corners and out brake the competition. Carbotech™ has won multiple pro races, national championships, and rally races all over the world. Our high performance street compound is our 1521™. The next in our lineup is our Autocross compound, AX6™.
Our race compounds start with the letters "XP™" then they are followed by a number. The first number is 8 (XP8™, then XP10, XP12, and XP16), and as you go up in numbers the initial bite gets much stronger, higher fade resistance, higher torque, and an increase in the temperature range. On that same note, as you go up in our compound numbers you will get slightly faster wear rate on the pads and a little more aggressive on the rotors. That being said, even our more rotor aggressive compounds are still much more rotor friendly then our competitions compounds.
For more information please visit our website at ctbrakes.com or give us a call at 877-899-5024.
Thank You for your time,
Old May 11, 2008 | 08:10 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
Sounds good.
Which pads would you suggest for for 996TT to be used 4or5 DE events ,advanced group with R compound tires. moderate or light street use?
Elliot
Old May 12, 2008 | 01:15 PM
Hey Elliot,
For track use with R compound tires I would recommend XP12 for the front & rear of your 996 Turbo. That will give you the best bite, consistent torque, and modulation while still being rotor friendly. 4 or 5 DE events shouldn't be a problem at all (varies from driver to driver, and from track to track).
Our brake dust is 100% NON Corrosive so it will not eat the paint on your nice wheels, and it rinses right off without any real scrubbing.
Our 1521 compound is our high performance street compound. You will get better performance vs. the OEM pads, along with A LOT LESS BRAKE DUST. The brake dust is light gray in color, not the dark black dust that you get from the OEM pads.
The 1521 compound is a lot easier on your rotors too, giving you almost twice the life out of them vs. OEM pads.
Old May 12, 2008 | 01:19 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Welcome to the site. Carbotech brakes are very nice pieces. I know that Motorsport Technologies Inc. (MTI) here in Houston recommends them for their heavily tracked cars. I had a set ordered for my Diesel that I never got to put on because I sold the truck I do plan on putting a set on my 996TT when it is time for new pads.
Old May 12, 2008 | 08:04 PM
Turbohead's Avatar
Originally Posted by CarbotechDanny
Hey Elliot,
Danny,
are you suggesting a different set for street ? What about the rotors? couldn't I use the Xp12 on street. so idon't have to change.?
Elliot
Old May 13, 2008 | 06:46 AM
Elliot,
Technically you could use XP12 on the street. Do I recommend it? No. It will make a decent amount of noise when driving, but they will work. You can run 1521 and XP12 on the same rotors so you don't have to change out your rotors.
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 01:23 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
