New Tire Issues
Old May 14, 2008 | 06:11 PM
joshemmick's Avatar
joshemmick is infamous around these parts
New Tire Issues
This spring I replaced my conti. contact sports with mich. pilot sport's. They are mounted on 19" Techarts. Since the change, the car does not feel solid at speed. I have the pressures at about 36F and 44R What tire pressures should I be running? The sizes are F 235/35-19 and R 315/25-19. Also the driver rear tire rubs on the inside of the top of the wheel arch over some bumps and under sever cornering. WTF? Has anyone had problems like this? Are the Mich. Pilots junk? My local P dealer said more people were buying Mich over Conti so thats what I did. Any thoughts?
Old May 14, 2008 | 06:59 PM
djantlive's Avatar
u are running on stock suspension setup right?
i think the upsized tire is right size. michelin are known for slightly smaller width so you shouldn't rub. not sure why it's doing it for you. guess you could add a small spacer if rub continues or if you are running on coil over you can adjust stiffness.
does the car bump around more? MPS should be softer than other tires. Are you comparing this setup with an 18" stock setup or just tire change alone?
Old May 14, 2008 | 07:02 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
doesnt a spacer push the wheel out further? wouldnt that rub even more?
Old May 14, 2008 | 07:39 PM
WOODTSTER's Avatar
Need to find out what ET (offsets) on your wheels are.
I run same size tires and have no rubbing (except occasionally at full lock...very light
front fenderwell rubbing).
MK
Old May 14, 2008 | 07:45 PM
joshemmick's Avatar
Yeah, stock suspension. It just doesnt seem as sure footed as it did with the stock wheels. I have conti's on the stock wheels and had conti's on the techarts until now. I still have contis on the stock wheels and it handles and feels like it should. Last summer it seemed to handle even better on the techarts with contis. When I drive the car at speed now it just doesnt seem to handle as predictable as it should. Nothing else hase changed except the diff tire manufacturer. The only things I can think of are the tire pressures or the tire compound. Even if the mps are softer, I wouldnt think it would make the car seem loose at speed. I'm stumped.
Old May 14, 2008 | 07:47 PM
joshemmick's Avatar
MK
What is the best way to measure the offset?
Old May 14, 2008 | 08:02 PM
LT1's Avatar
LT1
LT1 is infamous around these parts
I'd double check the balance weights. Swap out the front/rears with your old set of rims/tires that were known to feel right to see if you can pinpoint the rim/tire that might be balanced incorrectly.
Old May 14, 2008 | 08:07 PM
WOODTSTER's Avatar
Some People cannot stand the way M PS2's feel, I like em althought they really felt
squirrely the first 3-400 miles until the release set in on the new tires.
The sidewalls feel much softer than the Conti's but the PS2's are a Fantastic street
tire and an excellent track tire unless you are trying to set lap records (leave that to the Hoosiers)
MK
Old May 14, 2008 | 08:18 PM
joshemmick's Avatar
please excuse my ignorance..."until the release set in" what does that mean? The tires only have about 100 miles on them so far. Looks like I need to go for nice long drive.
Old May 14, 2008 | 09:17 PM
spoonito's Avatar
spoonito is infamous around these parts
From my knowledge (some one correct me if I'm wrong) new tires need to go through a couple heat cycles to break them in. Not 100% sure. I would say put another couple hundred miles on them and if that doesn't help, try adjusting the tire pressure.
Old May 16, 2008 | 03:14 PM
Adam Bowles's Avatar
Adam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud ofAdam Bowles has much to be proud of
When tires are molded, the molds are covered with a release agent so the rubber doesn't stick. This release agent bonds with the outermost part of the rubber, so it takes about 400-500 miles to wear it all off. During this period, the tires will not act normal, so give it some time before you pass judgment on the PS2's.
horsepowerfarm
Sep 10, 2015 06:09 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
I'mAllIn
Aug 25, 2015 09:44 AM
Zero911
Aug 24, 2015 06:51 PM
