What would be the Best mods to get for $3000?
Old May 15, 2008 | 12:45 PM
  #31
Darkclaw13's Avatar
Darkclaw13 is infamous around these parts
Originally Posted by LUISGT3
Coilovers a proper alignment and corner balance and a Drivers Education event so you can learn how to drive it well.
^^^^Thats exactly what I was going to say.
Old May 15, 2008 | 12:49 PM
  #32
OCTurbo's Avatar
OCTurbo is infamous around these parts
Like others said, go for an ecu flash (i prefer giac), followed by a new speedtech/dgi exhaust.
Old May 15, 2008 | 12:52 PM
  #33
thankful's Avatar
thankful is a glorious beacon of lightthankful is a glorious beacon of lightthankful is a glorious beacon of lightthankful is a glorious beacon of lightthankful is a glorious beacon of light
Originally Posted by vividracing
Here is a link to the K16/16G upgrade - http://www.vividracing.com/catalog/a...5-p-46738.html
The ECU Flash is done via OBD II flash cable from us via Softronic. Price on the flash is $1995 and includes the OBDII flash cable.
Do you need the whole car - or just the computer?
Old May 15, 2008 | 03:20 PM
  #34
Softronic's Avatar
Veteran: Marine Corps
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
Neither is required. You can have the Turbos removed and the exchanged ones installed. All of these types of upgrades require the old turbos to be sent back for modifications. The Turbos are K16 that have been opened up on the charging side to make a K16/16 and the waste gates are updated.
The flash is sent to you or the shop that is installing them via email as an attachment and a simple laptop and cable that is supplied will flash the car.
The tuned package of a Stock K16 or 16/16 are very close in the final outcome.
Best,
Scott Slauson
Old May 15, 2008 | 03:54 PM
  #35
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Originally Posted by Seal Grey Matte
Speak to tony at European Performance Labs (a board sponsor)
http://www.eplabs.net/contact.html
Thanks Micheal!
We have approx ~25 cars running with out k16/16g kit so far with very good results.
$3345 was our intro special for the kit and was supposed to expire May 1st however we have extended this pricing through June 1st. The kit includes everything you need to bolt the turbos to your car and enjoy (gaskets, hardware, ecu flash ect).
Old May 15, 2008 | 03:57 PM
  #36
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
I've had both. In my experience, there was a significant difference. Do you have dyno plots or other data supporting that conclusion?
Old May 15, 2008 | 03:59 PM
  #37
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
softronic what increase in HP does your flash give a stock 2003 996tt?
Old May 15, 2008 | 04:13 PM
  #38
Softronic's Avatar
Stock K16's yield about 500Hp and 545 of torque with a stock Softronic tune. The K16/16 can yield more as with the K16's with more boost and fuel, this basically applies to all turbo cars. More boost more power.
My expertise is 25 years of tuning and race engine building for Porsche.
Best,
Scott Slauson
Old May 15, 2008 | 04:15 PM
  #39
boca996tt's Avatar
and it works the same if the car has aftermarket exhaust new diverter valves, bmc air filter? How does the flash get installed?
thanks
Old May 15, 2008 | 04:26 PM
  #40
Softronic's Avatar
thanks
Softronic or one of its Dealers would send you a cable that will read out your current data. This is then uploaded and I make a custom file for each individual car. This applies to all files done by Softronic. The new file is emailed to you along with the original and you can flash to either one as you may require.
The Durametric Diagnostic tool is also an option in the NA cars or standard for Turbos.
You can read on this tool at http://Durametric.com .
Best,
Scott
Old May 15, 2008 | 04:42 PM
  #41
Stock K16's yield about 500Hp and 545 of torque with a stock tune.
Maybe I'm missing something. Stock turbos & stock tune makes 500 crank?
Also, my results were 420awhp 490awtq on stock K16s with a 1.1 bar flash and 480awhp and 530awtq with K16/16g with a 1.1 bar flash (both pulls were all wheel drive and on 93 octane). So really it's same boost, different turbo, more power.
Are you saying that Vivid/softronic's K16/16g kit makes the same power as a flashed K16 car?
Old May 15, 2008 | 04:45 PM
  #42
Softronic's Avatar
Stock Softronic Tune on a K16.
Best,
Scott
Old May 15, 2008 | 04:51 PM
  #43
Scott,
(1) Have you or Vivid installed a K16/16g kit on a car yet?
(2) What were the results?
Old May 15, 2008 | 05:28 PM
  #44
Softronic's Avatar
Scott,
Yes I have and the 16/16 has been out for some time now. The results are typical of what one would expect from the mod and the most recent car that I did it on was J Cipriani and Randy Pobst car in which is a twin plugged 993 Race car.
Best,
Scott
Old May 15, 2008 | 05:42 PM
  #45
Maybe we were talking past one another.
I thought you were saying K16 at 1 bar = K16/16g at 1 bar. Which, in my experience is not accurate.
Re-reading your posts, I now think you were saying: K16 at 1 bar = K16/16g at .7 bar (which may be right, but I've never run mine at stock boost levels).
I'm still curious to see a dyno plot of a Vivid/Softronic 996TT K16/16g car. Will you post one up when it becomes available?
