PS2 Owners Be Careful and Check Your Tires
Old Jul 23, 2004 | 01:16 AM
AMG ETR's Avatar
Re: Re: PS2 Owners Be Careful and Check Your Tires
Originally posted by damon@tirerack
It is possible to bubble a tire due to impact with no other visible signs inside or out. We see it daily. If the bead is that soft, I would have it checked out, too.
I was told by a couple tire guys down here that an impact to create as big of a bubble as I had would have made a cut on the inside and probably bent my rim (yes they were that big).
Evan
Old Jul 23, 2004 | 02:27 AM
HotRodGuy's Avatar
Originally posted by limitup
Michelin says to run stock pressures of 36/44. What makes you think this is "way too high?" Do you know more then they do?
I've just never ran temps that high and haven't seen people run them that high on other cars. You guys may be different, but everyone I know runs 32 cold, but then again, none of these cars are the 996 TT w/ these tires.
44 seems pretty excessive. That means that when it's heated up you are running around 40/48
Old Jul 23, 2004 | 05:17 AM
nman413's Avatar
nman413 is infamous around these parts
That's too high. I run 36/38 on the street and quiet a bit lower at the track.
Old Jul 23, 2004 | 05:24 AM
03-turbo911's Avatar
Senior Member
It's better to stick to the factory recommendation if you're on 19"s. On 18"s it's a diffrent story.
Old Jul 23, 2004 | 05:30 AM
tuner's Avatar
tuner is infamous around these parts
just found a picture of the one and only AMG ETR
just before his prom.
Old Jul 23, 2004 | 06:20 AM
AMG ETR's Avatar
Sure...wait till I leave early today...
THIS MEANS WAR!!!!
Evan
PS-Isn't Bryan Cute??:
Old Jul 23, 2004 | 07:10 AM
HotRodGuy's Avatar
i didn't even realize he was running 19's. That changes the game probably.
But still, i'eve never heard anyone run the recommendation. I also thought the recommendation was the MAX PSI to run. 44 cold seems WAY WAY to high, that's 48psi warm. Most tires I know of can't handle that.
Old Jul 23, 2004 | 07:25 AM
AMG ETR's Avatar
Max on these is somewhere in the high 50s I believe.....315/25/19
Evan
Old Jul 23, 2004 | 07:33 AM
HotRodGuy's Avatar
that's a whole lotta psi
Old Jul 23, 2004 | 08:02 AM
911 flyn's Avatar
Senior Member
911 flyn is infamous around these parts
Porsche says 44 rear 36 front on 18's (factory recommendation)
Old Jul 23, 2004 | 08:36 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Man that's high...Porsche spec on N-Spec PS2's for the GT3 is 32F and 39R cold pressure.
Old Jul 23, 2004 | 08:51 AM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
Wow really? I don't know much about tire pressures, or cars for that matter ... I just like to drive 'em. But why would there be such a big difference between the GT3 and TT? I assume because of the weight and RWD vs AWD? I guess it's just a little confusing when Porsche and Michelin say to run 36/44 and then you have a bunch of people here swearing that's way too high. Hrm...
Old Jul 23, 2004 | 09:10 AM
rockitman's Avatar
I bet it has to do with the fact that the published pressures for the TT are based on 18's N-Spec tires the car is delivered with. I don't believe 19 PS2's fit that bill, so all bets are off...Without a doubt, the 19's must be run at lower pressures than those spec'd for 18's in the manual...
Old Jul 23, 2004 | 09:15 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
Cool EGO
Attention!!!
Trust Michelin.
They were founded in 1889!!!
Don't let your EGO get in the way of your safety.
Ciao.
Old Jul 23, 2004 | 10:05 AM
limitup's Avatar
I've got PS2s on my 18s and figured I'd start with the recommended 36/44 and so far it seems fine. I haven't had them on long enough to really say, so at this point I'm just trying to put some miles on the tires before I start messing with tire pressures and making any real judgements on the tires.
