Pics & Install of the Agency Power Carbon Fiber Cold Air Intake
SubscribeThank you!
Quote:
So how did you get it in there without scratching the CF???Originally Posted by kilrgt
Its not hard to install, the only tricky part was getting the mass air tube on to the filter with little room.
When your installing it you really just need to take your time, Its alto of twisting and pulling.I really haven't had any time to get out and test it, so I cant answer if its made a difference in performance, I can say with no doubt it looks great.It's been very very hot here and the temps are AIT have been higher but I am sure it has to do with the weather and not the box.I will get out tonight (Sunday) for a little testing and I will update my post.Also someone asked how much it was, I paid $900.00 plus shipping from Dan @ Vivid Racing.
You should look at the difference between outside temperature and air intake temperature while cruising.Mine is a difference from about 5 till 8 degrees warmer then outside temperature (degrees celcius).
No free lunch here. Thanks for the review Paul!
