Error Code P0103 and ABS, PSM and Check Engine Lights
Old Jul 27, 2004 | 03:58 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
The dealer got the following data from the ECU.
The stored Error Code is P 0103: "Mass or Volume Air Flow Circuit High Input"
Here is the engine data from the exact moment when the error occurs (ABS, PSM and Check Engine Lights):
Calculated Load 100%
Coolant Temp 187 F
Short Term Fuel Trim B1 -7%
Long Term Fuel Trim B1 0.655%
Short Term Fuel Trim B2 -7%
Long Term Fuel Trim B2 0.655%
Manifold Pressure 75.5 in Hg
Engine RPM 5750
Vehicle Speed 83 MPH (the RPM and Speed data indicate 3rd gear)
Does a Short Term Fuel Trim of -7% mean that the car is running lean? Could that cause the problem?
Is it possible that a larger Fuel Regulator is needed?
Thanks for your help.
Old Jul 27, 2004 | 08:35 PM
PorschePhd's Avatar
That is the typical error for the MAF. They simply need to replace it.
Old Jul 28, 2004 | 01:37 AM
BlackBear's Avatar
I was concerned about this value:
Does -7% mean the car is running too lean?
What does Short Term Fuel Trim mean anyway?
Old Jul 28, 2004 | 10:20 AM
PorschePhd's Avatar
Don't be too concerned. The MAF can not read right and the system goes beyond its control limits. The system reads too lean based on what the MAF thinks it should be seeing. Once it stops reading correctly then the fuel is not adjusted properly and the mixture goes off. There are other things it could be, but 9 times out of 10 its this.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Jul 29, 2019 11:13 AM
Mini George
Jan 18, 2016 09:16 PM
