Problems with engine,runs like an old beetle
This afternoon I noticed the car didn't run good in higher gears and I saw A/F dropped to 10 ,normal it is around 11.5 at full throttle,but got no cell's,tonight I wanted to test again and the car drove very good again but suddenly I heard a big rattle coming from the engine and the check light flashed and got a message: DRIVE ENGINE RUN TO WORKSHOP.
Oil pressure is fine,A/F is fine and even boost is normal,but at low rpm and at idle car is making a noise like on old volkswagen beetle and shakes a little bit,seems like he is running on 5 cylinders.I have the brockway r920 and it shows no DTC errors.I hear no rattling noise anymore but the car makes a very strange exhaust sound and shakes a bit.Anybody got an idea what the problem could be?
Have it towed to your shop. Don't drive it. You mentioned you had a strange exhaust sound. If you are lucky it is indeed an exhaust issue which can be fixed very easily. A bad cat or baffle in the exhaust could cause these symptons but I tend to think it's something more serious. Keep us posted and good luck.
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
