would running a 295/30-19 be bad for my diff?
Old Jul 25, 2008 | 09:36 PM
Imolas54's Avatar
Imolas54 is infamous around these parts
with a 225 front?
Old Jul 25, 2008 | 09:52 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
No as long as your rolling diameters front to rear are not off by more than half an inch.
Old Jul 25, 2008 | 10:39 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
i think a 245 front is the better match
Old Jul 25, 2008 | 11:13 PM
CarNerd's Avatar
What does this have to do with helping wear on the diff...?
Old Jul 25, 2008 | 11:25 PM
Turbo Fanatic's Avatar
Do you have a GT3? If your car is RWD all you really to worry about is keeping the front and rear tires pretty close to keep the ABS working properly. My guess is 295/30s are fine. Either way you can't damage anything in a RWD car since side to side diameters are perfectly matched.
AWD cars have a clutch like CENTER diff (viscous coupling) that tries to keep the front wheels rotating at approximately the same speed as the rears. If the front/rear wheels are of vastly different diameters, the viscous coupling can overheat and fail.
My personal opinions is that 30 aspect rears provide much better wheel protection due to slightly more sidewall. matching the fronts with a slightly bigger diameter (maybe 245s in the same aspect as stock) is a great idea especially on AWD cars.
vr6tee
Sep 16, 2016 10:41 AM
shifter_
Sep 8, 2015 12:07 PM
riverflyer
Sep 1, 2015 04:22 PM
porsche42
Aug 28, 2015 06:53 PM
The Oss
Aug 24, 2015 08:19 PM
