Front Differential Chewed due to incorrect wheel/tire se up
Let me understand. It's not the diameter but the radius? I'll let you think that over some more and try to answer yourself why using diameter and radius measurements will give you the same answer in the end. I have a 4th grade geometry book that might help you out.
First, the overall diameter is going to change based on the width wheel you mount it on.
The radius from the wheel centerline to the road is what needs to be considered. Think about what happens when you put drop the car to the ground. Pressure from the weight of the car on the tires changes the shape of the tire at the contact patch. The distance from the centerline to the road will not be the same as from the centerline to the top of the tire.
I've run different sizes because of the limited/zero availability of the OEM tire sizes, as well as because I have both 18" and 19" wheels. I thought the 19" wheels were causing problems even with a very small diameter difference until I put some brand new R888 track tires on OEM wheels and guess what: Still having PSM/CEL issues!
There's way too much heresay out there on this topic, plus unless people are actually measuring their tires to see what the real size is, this whole discussion is pretty much useless IMHO.
P.S. In my particular case I'm leaning towards a bad ABS sensor as the root of my CELs, but haven't had a chance to replace any of them to see if that fixes it.
Like I have said on previous posts and had a thread about it in the past...
I have ran a .5'' difference now for the around 25,000 miles, numerous dyno pulls, long road trips and many 175+ mph pulls with Zero issues,, I get my car checked by Porsche techs when it in the shop. They have told me that will not cause a failure Now, like they were lead to believe in the past also?
Also don't go by published OD because they usually are not measured on our size rims.. Wider rim smaller OD,, narrower rim larger OD.. I have measured the tires mounted on our stock rims.. I have posted all this stuff in the past.
Just giving you my experience.
Again, unless someone is using an obvious wrong set-up, whether that be a mismatch between front and rear, or even mounting to an incorrect rim size, it's highly improbable that minor percentage differences in the tires radius/diameter/circumference will mean anything.
Over 250 posts and not one person can offer any evidence to say otherwise. I know there are a lot of smart Porsche owners, but no one knows.
Radius of the tire when mounted to the wheel and on the car is actually a more important measurement than the diameter listed on the manufactures spec sheet.
A= diameter (converted to feet) times Pi (or Pi time radius squared for those who think radius matters most). This gives you circumference. Then take 5280 feet (distance of one mile) and divide by A and magically you get RPM.
You may not get the exact number shown by manufacture but it it'll be real close. Remember, whatever percent difference you have at RPM will be the same for diameter or radius.
Don't forget to account for your rim size an tire pressure and sprinkle you magic Porsche fairy dust.
Come on guys. All this talk about diameter and radius and now it's RPM. How do you think RPM is calculated?
Also, What do you call real close? I have seen and measured tires on many rims.. A .5'' difference in rim width usually is about .25 '' to .30'' difference in diameter.. Also seen tire specs vary from published given specs.
Remember we are dealing here With Porsche people,, that need and want to be to the exact specs within the box.. LOL.
An explanation from TireRack states:
"Revolutions per mile indicates the number of times a tire revolves while it covers the distance of one mile. Depending on the tire manufacturer, revolutions per mile may be either measured in a laboratory or derived from calculations based on their previous test experience.
Tire revolutions per mile cannot be calculated by simple math because the tire tread and sidewall bend and stretch (deflect) when the load of the vehicle presses the tire against the road.
Since the resulting loaded or rolling radius is less than half the tire’s published overall diameter (which would only reflect the tire’s unloaded radius), calculating the tire’s absolute rolling circumference isn’t possible.
Additionally, a tire transitions from an unloaded to loaded state as it rolls, continuously flattening where the tread footprint comes into contact with the road. These continuous transitions result in some tread slippage, again increasing the tire revolutions per mile beyond what simple math would indicate."
What I'm more interested in finding out is the design of the differential that we're all concerned about. A differential is suppose to account for the differences in rotational speed and in most cars is working almost ALL the time (unless you only drive in a straight line
). Is the center differential for the AWD cars really designed to handle less than the front and rear differentials? Just curious....P.S. The Porsche fairy dust is the most important component
