You gotta be kidding me! - 997 GT3 Spy Photo's Already?? Looks amazing!
I had a feeling they would use this front end.
1 Attachment(s)
:D
awwe-some!
I like the front, not so keen on the Exhaust.
Do we have any performance specs yet?
Originally posted by john stephanus Do we have any performance specs yet? http://www.autoweek.com/news.cms?newsId=100684 |
400hp
Is the 997S 3.8 an oil pan or dry sump system???
Originally posted by BlackBear 400hp |
Originally posted by rockitman Is the 997S 3.8 an oil pan or dry sump system??? |
Can you explain the difference?
I LIKE!
Originally posted by Shawn C Can you explain the difference? That does not mean the 997 won't have one...The motor may be based off the 997 3.8, but if they do it right, they will use a dry sump system and lighten and strengthen rods, valves and pistons like they do on the current model.. |
Originally posted by rockitman Dry sump system means there is a separate oil tank that holds the bulk of the oil rather than an oil pan. There are various pumps that continously pump the oil throughout the motor making the motor much less susceptible to oil starvation under heavy lateral G's. Keeps the oil where it needs to be. Starvation can be a problem with oil pan type motors under sustained lateral G loads. That's why most race motors use the dry sump. T |
hold back guys, would it be the new aero kit for the 997? just a thought!
| All times are GMT -6. The time now is 09:07 PM. |
