My day at the 1/4 mile track
Old Nov 2, 2008 | 07:20 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
1800-2000 any more i would blow the tires. i tried to feather it one pass and then smash it and blew them away. that track was in the 40- 44 today. no mater what i tired it wouldn't bite.
Old Nov 2, 2008 | 07:36 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Very respectable time in that cold air not to mention those tires are not even designed to get a good grip. With better tires you will improve your 60 foot then you are dancing.
Old Nov 2, 2008 | 07:59 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Those tires actually work quite well for drag racing in AWD configuration, we've cut good 60's on PS2s, both the stock sizes PS2s (1.61) and 19" PS2s (1.68). At 40-45 degrees you won't find many tires that can hook, as the track is dead cold. Take a pyrometer and find out what the track temps are when it's that cold out vs tire temps to compare. A hot track (over 100) is bad, but a cold track is just as bad, especially when you're making a ton of extra HP.
Old Nov 2, 2008 | 08:06 PM
Good Point Wes no one was hooking there today i mean maybe 25% of guys were that had suspension work and a real sticky tire. I have had the car hook hard on the street when it was 70 outside.. man i miss that weather already!!
Old Nov 2, 2008 | 08:33 PM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
my teeth were chatter'n watchin today... IT was cold... the wind wasnt helping.
As for shift points any higher would yield higher times.. Been there.. done it. That kit works best with those shift points. His problem was traction not the rest. HE does have a ten in that set up! Just need more traction and bit of fine tweak'n! He knows what im talking about...!
Old Nov 2, 2008 | 08:37 PM
oh the a/f gauge?
Bro i had the seat heaters on staging and for the pass!!!
Old Nov 2, 2008 | 08:38 PM
Why didn't you run some better gas and turn it up to 1.3 bars ...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 2, 2008 | 08:43 PM
i couldn't hook at 1.1 and you want me to turn it up to 1.3??? i did one pass and i pedaled it 2 times got off one point cause it was almost sideways! still ran a a 15.2 at 117 LOL it looks good on Video
Dont worry Mark I plan on turning up the wick if the weather holds out!
Old Nov 2, 2008 | 08:49 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Yea it was a good day, Corey did well and I was happy to see him represent. The car has more in, I have do doubt about it.It was a little too cold for almost any tire.The MPH is there , getting the power to ground is the key.I think we will have one more weekend to get the car into the 10's, and as I said the car has it in it.Good day!
Old Nov 2, 2008 | 09:15 PM
art4iza's Avatar
I am glad to hear this result. Best 60 foot I got from my PS2's were 1.8 on 19" rims. Do you think this matters?
Old Nov 2, 2008 | 09:16 PM
I see...
you could have hit the buttom in high boost in 3rd gear manually lol
9.66
click to view
Old Nov 2, 2008 | 09:46 PM
LOL i wanted to do that and someone said i was nuts!!!
Old Nov 2, 2008 | 10:02 PM
DMaffo's Avatar
not me!! lol....
Old Nov 3, 2008 | 12:39 AM
Divexxtreme's Avatar
Originally Posted by hollywood996tts
Can someone please chime in hear that has experience with the k24/18g's or a Proto650 tune? Why would the shift points be what appears to be so low as mentioned above 6200-6000-6100, when like in my case the rev limiter has been raised to 7200-7500ish and I typically shift closer to those #'s thinking that I am getting more push. Am I not? Is it only in my head? Is is possible my times would be better if I shifted earlier?
I've tried both and I have always gotten my best times by shfting right at redline.
Old Nov 3, 2008 | 05:24 AM
I will have to try a pass that way as well Scott. you do have alot of runs under your belt so there is a positive to it.
