Any gains with Headers on a Stage 2 ?
Old Sep 4, 2004 | 05:21 AM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
I would like to know if just adding Headers I will get some gains on a Stage 2 996tt.
Does the special merge collector accelerates exhaust flow to the turbine for faster spool up?
Does this really means better low end torque and acceleration?
Old Sep 4, 2004 | 05:26 AM
sharkster's Avatar
Waste of money on a stage II.. you can do other things for much better HP gains
Old Sep 4, 2004 | 11:18 AM
PorschePhd's Avatar
You don't pick up any more HP in the lower stages, however you do drop spool times a bit. The last set of dynos we did we drop apx 250RPM on the powerband. Not a ton, but adds drivability. Is it worth the money, well it depends on your budget. If you plan on going up HP scale then it is a piece you will eventually need and already in place. It is all about what your goals are
Old Sep 7, 2004 | 06:43 AM
Thanks! Stephen
COBB Tuning
Mar 29, 2016 09:26 PM
Marcos AMV8
Dec 18, 2015 06:03 AM
jyupitt1
Sep 23, 2015 06:26 AM
The Oss
Aug 24, 2015 08:19 PM
