Rear Spoiler
Old Dec 11, 2008 | 02:42 PM
Flying Viper's Avatar
Flying Viper is infamous around these parts
Spoiler
After PM's to you Jon, I want to thank you for all the advise you gave to me and others. It was a big help. Still couldnt do the job myself, but it helped in understanding and when speaking with the Porsche folks.
I'am new to Porsches and must tell you all that I like it better than any of the Vipers I have or had.
Thanks again for the help
Tony Chris
Old Dec 11, 2008 | 03:39 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Tony Chris
Thanks, Tony, and welcome. The group here is really great when it comes to sharing what they know and trying to help. Glad that I got a chance to give some back.
Jon
Old Dec 11, 2008 | 05:24 PM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
Great write up. This seems to be a common problem.
Old Dec 11, 2008 | 05:53 PM
mfm's Avatar
mfm
mfm is infamous around these parts
I removed everything as directed, no problem. I got to the last step where the metal plate is removed to expose the flat screwdriver like portion of the motor. Each of the 3 screws broke in half. I was able to remove these and will get new ones. However, I hooked a voltmeter to the electrical connectors and upon pushing the up button there was not reading. When the motor was hooked to a power source the motor turns fine. There is no sign of leaking hydraulic fluid. What to do now?
Old Dec 11, 2008 | 07:49 PM
FAST FWD's Avatar
Now that's bad luck breaking all 3 screws. Thinking out loud now...
I thought that you said that you could hear the motor turning when you pushed the up button with the assembly in place? The way you describe it now sounds like an electrical issue. Did you check the fuse?
I assume that you meant that the motor turns fine when you put an external 12V on it? If that's true, when you reassemble it does it drive the spoiler? As I recall, reversing polarity reverses the motor. You should be able to drive the spoiler up and down just by putting 12V on the motor leads. There must be limit switches somewhere to control the travel, but I don't recall where they are.
Jon
Old Dec 20, 2008 | 12:32 PM
ej96hatch's Avatar
ej96hatch is infamous around these parts
My uncle has a 2002 tt and I noticed today he had the same problem with his rear spoiler. The driver's side stayed down and the passenger side raised. I continued to wash the car and when I got to the back and sprayed the decklid with water I noticed a rainbow color film coming fromt the middle of the decklid. So after drying the car I opened up the lid and checked it out. First I noticed that the seal/weather stripping was coming off in one place. After touching it to try and stick it back my fingers had brownish/goldish fluid on them. I followed the fluid up to what I believe is the pump/motor assembly underneath the plastic cover. I was thinking of trying the wd-40 but that probably won't work and leaking fluid means there is a bigger problem elsewhere. I'm thinking maybe the system is leaking on the driver's side since that side stays down like it's getting no pressure at all. There is no fluid on the bottoms of the hydraulic shafts. I am pretty good with taking things apart and putting them back together. Before I take anything apart could someone suggest what they think is wrong first?
Old Dec 20, 2008 | 03:40 PM
FAST FWD's Avatar
Sounds like a leak in the hydraulic line on the driver's side. If you follow the thread above, I explained how the system works. The two sides are separate.
I have the original one from my car in a box, picture above. It includes the motor, hydraulic lines and the pistons that attach to the spoiler. The only thing wrong with it was the loose set screw on the motor coupler - now fixed. PM me if you want it.
Jon
Old Dec 21, 2008 | 09:50 AM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
Wow, thanks. Do you have any pics of said screw?
Originally Posted by FAST FWD
WD-40 on what - the metal tubes? That's a good idea if they are moving intermittently, but not if the spoiler isn't moving at all. I posted this to the guys who PM'd me, although I don't know why I asked them to do that.
Here's what I told them:
Mine started giving the light intermittently, and then gradually progressed into not moving. I ended up replacing the whole assembly, for a price similar to what you've been quoted. I later took apart the old one, and discovered that it was something really simple. Not sure this is your issue, but for $1300, it's worth a look:
The system works through a motor/pusher assembly that is a long metal tube bolted to the underside of the decklid. The motor drives a worm gear that pushes hydraulic fluid into the two tubes under the spoiler to raise it, and when the motor reverses, it sucks the fluid back in to draw the spoiler down. It's basically a pair of syringes with plungers driven by an electric motor.
The motor is connected to the worm gear with a tab kind of like a flat-blade screwdriver that is held onto the motor with a set screw. In my case, the set screw had backed out, and that made the motor slip. The warning lights come on at first because the spoiler isn't moving as fast as it should (I think). Anyway, tightening the set screw fixed the problem. Too bad I learned that after spending all that money.
It's not trivial to get to the set screw. It sits basically in the center of that long cylinder. One end of the cylinder is filled by the motor, the other end by the hydraulic reservoir. You need to take the cylinder off of the decklid, then figure out how to get it apart (it was a couple of years ago - I remember it was a little tricky to separate, but I don't remember why). Once you do though, you just tighten the set screw if it's loose and you've saved yourself a chuck of change.
If that isn't clear enough, I have the old one in a box and can send you some pictures.
I hope that helps. Let me know.
Jon
Old Dec 21, 2008 | 12:19 PM
FAST FWD's Avatar
See posts #11 and #12 in this thread...
Jon
Old Dec 23, 2008 | 10:53 AM
Webtool1's Avatar
Webtool1 is infamous around these partsWebtool1 is infamous around these parts
From reading these posts it sounds like there are a pair of hydraulic cylinders being driven by a single electric hydraulic pump with the cylinders connected in parallel. In this setup, if one cylinder (side) has more drag than the other, then it will rise slower until the other side dead ends full up. At this point the dragging side will rise. Is there any sort of proportioning valve in the circuit?
Old Sep 6, 2009 | 01:47 PM
frog1's Avatar
frog1 is infamous around these parts
Question
Jon,
It took a couple of hours, a bit more than you (kind of a long party last night so this morning the thoughts were not so clear ) ... I reached the same point as you... but everything looked normal, the screw was still strongly tightened... so I put everything back and I think now the culprit may be the upper potentiometer switch (it is actually not a pot. but a system with 2 switches 1 lower and 1 upper)... on the picture everything look fine but there is a wire exposed, so it may not make good contact at the switch anymore.. I'll try to by-pass it now with an extra wire and see if it fixes the problem...
Old Sep 6, 2009 | 09:43 PM
dog4delta's Avatar
dog4delta is infamous around these partsdog4delta is infamous around these parts
If the motor is running and the wing does not go up and down symmetrically, then the probable culprit is uneven (or insufficient) hydraulic fluid servicing in the two cylinders in the pump / motor assembly. That was the problem I had. Each cylinder has it's own fluid - - - there is no sharing or ability to "equalize" fluid between the cylinders and rams. If one of your cylinders has developed a slight leak over the years and now has a slightly lower amount of fluid than the other cylinder, the result will probably be a spoiler malfunction light. Tell tell signs of a fluid leak is fluid leaking out of the bottom weep holes of the rounded black plastic caps that snap on the bottom of the rams.
Here's how I "refilled" both of my cylinders. My disclaimer is that your results may vary, but this is a pretty simple closed hydraulic system so in reality there's not too much that can be screwed up.
Take the entire motor and ram assemblies out of the car. Yes, you have to remove the wing and lots of stuff from the deck lid to get this stuff off the car. You will need a relatively strong battery charger or other 12 VDC source to run the pump electric motor. Jumper cables from a batter will work if you can manage not to short the cables together.
Once everything's off the car and on the workbench, connect your power source to the electric motor leads to check the polarity. Depending on which way you connect the power, the rams will either go up or down. You want to start with the rams all the way down. With the rams all the way down and with the pump assembly held in a vertical position, carefully disconnect both of the hydraulic lines (one for each ram) on the end of the pump assembly. Make sure the lines are at the TOP of the pump assembly, and also note the proper orientation of the lines. Once you have the lines off, keep the disconnected lines held high so as not to let any fluid spill from the lines or rams. Now, while still holding the pump assembly vertically, in each of the holes of the pump assembly where you removed the banjo bolts from each ram hydraulic line, carefully fill each "hole" with suitable hydraulic fluid. I say "suitable" because in reality I don't have any idea what the Porsche spec hydraulic fluid actually is. I used hydraulic jack oil which is available at most automotive parts stores. I'm sure it's not Porsche spec, but it has worked well over the past year with no problems what-so-ever. If your hydraulic cylinders are low, each one will probably take several ounces. Fill each hole until fluid spills out.
Now carefully reattach each ram hydraulic line banjo bolt. If you've got each cylinder full, some fluid should weep out as you tighten up the banjo bolts. You'll find you either need an extra set of hands, or some type of a vice or clamp to hold everything vertically if you're working alone. Again, you don't want to let any fluid spill from the removed ram hydraulic line.
Now with everything back together, use your electrical power source and run the rams up and down several times. At first, one ram will probably slightly lag the other. If after a dozen times or so of running the rams up and down they are still uneven in their travel, the ram that is lagging is probably not quite full. This is what happened to me. I had to undo the banjo bolt of the ram that started to move just slightly after the other ram had moved, and add just a tad more fluid to it's cylinder. After I did so, everything started moving symmetrically.
There is another DIY that talks about "bleeding" the system by slightly loosening each of the banjo bolts and then applying power to the motor. My guess is that if you have air in the system, and you keep everything in a vertical orientation such that the banjo bolts are the highest points in the system, and if you keep everything held in this position long enough so that any air in the system can rise to the top (where the banjo bolts are), that this method may in fact work. However, I didn't have to do it so can't comment on its validity. However, if you have trapped air in the system, you'll need to find a way to get it out as air will surly cause problems in a hydraulic system.
Once I was satisfied that everything was moving up and down properly & symmetrically , I cleaned everything up and bolted everything back in the deck lid. Since doing this, I have not had a single spoiler fail warning light. If you've got everything in had to do the job (including the ability to remove the rear wing), it's no more than a couple hour job.
Bill
Old Sep 8, 2009 | 02:55 AM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
I used the same method as delta and it worked for me, but I used half pentosin chf11s hydralic fluid (porsche recommends, same fluid used in power steering pump) and half lucas power steering stop leak (lost fluid through leaky ram). But at first the ram still leaked but within a couple of weeks it stopped and been going strong ever since.
Old Sep 8, 2009 | 06:05 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Thanks for sharing !
Old Sep 8, 2009 | 08:00 PM
frog1's Avatar
guys, thanks for sharing this experience. So far, I could verify that the upper and lower sensors are OK, so root cause is probably the quantity of oil in the system (or lack thereof...) if there is not enough oil, then the upper switch is never activated because the piston does not move high enough. that mean back to square 1 and dismounting everything again as per your method... unless there is a way to refill via the pistons connections (removing the little plastic insert) with a T type connection and injecting oil from there?
