What are these?
Old Dec 18, 2008 | 09:07 AM
M32's Avatar
M32
M32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond reputeM32 has a reputation beyond repute
What are these?
I'm in the process of installing back my TA front and am wondering what this is and if I need to install it on the TA bumper somehow. (Sorry for the bad pics)
Also, any idea what this is? It was hanging loose when I took off the oem bumper
Edwin
Old Dec 18, 2008 | 09:12 AM
GT3 Chuck's Avatar
Administrator
I believe that is the outside air temp sensor and yes you do need to re-install it cause I think the computer uses the info for more than just displaying outside temp...
Old Dec 18, 2008 | 09:38 AM
M32's Avatar
M32
Thanks Chuck... I'll be sure to mount them somehow. Also, any idea what the thing in the second picture is?
Edwin
Old Dec 18, 2008 | 09:55 AM
GT3 Chuck's Avatar
Administrator
you will need someone more familiar with your model than I as to where that second device goes...it could be a collision sensor for the airbag system...does it fit in the end of that 90 degree vertical tube....otherwise I haven't a clue...
Old Dec 18, 2008 | 09:57 AM
M32's Avatar
M32
Haha...ok thanks. Appreciate the help
Edwin
Old Dec 18, 2008 | 10:43 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Can you provide a clearer picture of the item that you found hanging loose? What is it dangling from? I don't remember anything in that precise location on the shock absorber strut of my car.
The other item is the OAT sensor and will function properly if it is in its circular hold clip or just dangling loose as long as it is up in front of everything else.
Old Dec 18, 2008 | 10:48 AM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
First is the temp sensor as Chuck indicated - you do need to mount that in place (factory location is a receptacle on the bumper skin).
I can't make out the second pic to tell what it is...
