Advice for Suspension Install?
Old Sep 10, 2004 | 09:27 AM
DAVE W's Avatar
DAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to behold
Ok so my PSs finally came today and I put them on and they ROCK hard over the yoko avs sports I had and now its time to put the PSS9's in that I have had sitting in my shop for months now.
Anybody got any pointers, advice, or tips for me on the install? Especially with taking the rear interior apart, etc... I've done 100's of suspensions over the years but this its my 1st 996...
I'll be doing my own corner weights, and aligment setup as well...so feel free to share #s.
Thanks In Advance....
Dave w
Old Sep 10, 2004 | 01:47 PM
JC996TT's Avatar
JC996TT is infamous around these parts
PSS9's
The interior is quite easy to get out if you don't have the Bose option if you have the bose that box has to come out 1st.
I have installed several PSS9's in 996 and 993's and there are not that difficult. Trick is to set up the heights and drive around for a bit and then come back recheck (and adjust) then to alignments.
Old Sep 10, 2004 | 03:19 PM
StephenTi's Avatar
StephenTi is infamous around these parts
I've done my suspension 3 times... here're a few things that I found helpful.
Have an impact wrench. I used an inexpensive Harbor Freights 220 ft.lb. rechargeable impact wrench that worked great.
Unbolt the front 1/2 shafts at the front dif to make front installation easier and more efficient (allen bolts). There's also a triangle-shaped steel plate/bracket that needs to be partially unbolted and rotated aside to loosen the suspension arm... it'll be clear when you look at it. I didn't do this the first two times, and it cost me a lot of time.
Rear is very straight forward.
It's not too much off from doing VW or Audi suspensions.
Old Sep 12, 2004 | 07:14 AM
DAVE W's Avatar
thanks! Thats exactly the time saving sorta advice I was looking for.
-davew
Mark @ AIM Performance
119
Jul 28, 2021 08:07 AM
Jul 29, 2019 11:13 AM
Aug 19, 2015 06:35 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 18, 2015 01:04 PM
