FVD flash, BMC, div valves, 2002 otherwise stock, I am only hitting 0.7-0.8bar
Old Feb 28, 2009 | 02:05 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Which is what I was hitting before the flash. Waited to do div vlaves at different time so as not to confuse any boost issue. Car feels stronger with more pull but I have only put 700 miles on it before I did the flash, so its hard to tell. FVD says could be small leak some where but the boost never changed. If there was a leak wouldnt you see 0.6 before flash? Not the same before and after. This boost is at full throttle in 2nd and 3rd gear from 3000-6000rpm. Any way to test for leaks? Any chance boost gauge is inaccurate? Any ideas?
Old Feb 28, 2009 | 03:23 PM
996twin_sc's Avatar
996twin_sc is infamous around these parts
Put the car in 4th and go WOT....its more accurate than 2/3 gear.
Old Feb 28, 2009 | 05:07 PM
John@SpeedTech's Avatar
I had the FVD stage 2 flash for a few years and the most I ever saw was .9 - .8 is normal for that flash.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Feb 28, 2009 | 10:16 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
I see 1.1 Bar with the same set-up. Something must be wrong.
Old Mar 1, 2009 | 01:48 PM
dog4delta's Avatar
dog4delta is infamous around these partsdog4delta is infamous around these parts
Sorry for the thread hijack. Currently unable to PM.
Yves - could you shoot me a quick email with your address. I'd like to ask you a question about your set up.
Thanks,
Bill Underwood
dog4delta@charter.net
Old Mar 1, 2009 | 07:26 PM
jeff's Avatar
jeff is infamous around these parts
I have a 996tt 2001 i did the fvd stage 2 a mont ago. I see 1.0 to 1.1 bar in 2 and 3 gear
Old Mar 1, 2009 | 09:42 PM
After thinking a little more about this, I had one of the first FVD 996TT flashes back in 2002. I believe they recently went to a Softronic flash or something other than what I had, so my experience is not relavent to todays FVD flashes.
2022 Cayenne White
Old Mar 1, 2009 | 09:51 PM
Renegades's Avatar
Renegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of light
I had that exact setup up until like a week ago till i switched to K24s. Basically stage 2 FVD flash on K16s, stock exhaust, AWE DVs, BMC Intake.
In 1st and 2nd I could see around 1.0-1.2 bar but in 3-6th I could occasionally see 1.3 bar. These numbers are in ~20-40 degree weather.
Old Mar 1, 2009 | 11:01 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Using the WMW flashe AND the UMW wastegate upgrade kit along with the upgraded DV's and Europipe stage 1, I'm getting a consistent 1.1 and 1.2 bar output....but the wastegate kit seemed to be the most critical component of the higher boost. It seems that the system just can't sustain the 1.2 bar without the upgraded springs.
Old Mar 1, 2009 | 11:14 PM
Turbo Fanatic's Avatar
I don't think the original poster has a K24 car.
I believe the expected boost is 1.0 BR on flashed K16 cars.
And I agree fully that anything over 1.0 BAR sustained really requires a wastegate upgrade. It's a simple mechanical matter.
If you think about it, the factory springs are picked very well by the factory to act as safeguard.
Jul 29, 2019 11:13 AM
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
Sep 1, 2015 03:16 PM
Aug 20, 2015 12:17 PM
Aug 19, 2015 06:55 PM
