Stock turbo longevity...
Old Mar 12, 2009 | 10:46 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Originally Posted by TXGold
They were stock K16's Jimmer? Did you have a boost controller? What WHP?
Sounds interesting.
I have 59K on my car and stock turbo's and my car still runs hard.
Yeah, I ran more boost than I let on.
No idea the WHP. I had tight 1bar wastegate actuators, and modified the wastegate control solenoid and lines to allow for higher boost than the programming. Ran 21-23psi on the street, and according to my AFRs had plenty of fuel to do it.
Even "off the island" the K16s are a sturdy little turbo, and if you keep the air cool they can be very effective.
Old Mar 12, 2009 | 10:50 AM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
Originally Posted by jimmer23
I ran 1.5bar+ on my K16's for 2yrs (15k miles) and it never missed a beat. New owner reports car still running perfectly at 40k+ miles.
Just curious, but don't they max out at 1.2bar??
Old Mar 12, 2009 | 10:55 AM
jimmer23's Avatar
Nope.
Old Mar 12, 2009 | 10:56 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
from what i know 1.2 is the maximum boost for the k16 !
Old Mar 12, 2009 | 11:01 AM
jimmer23's Avatar
Efficiency-wise, yes. They'll still make power above that, but they're not technically rated to spin that fast and it may affect longevity.
Old Mar 12, 2009 | 11:06 AM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
+1 That's correct,
Old Mar 12, 2009 | 11:16 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Maybe 9 quarts of oil have something to do with it
The other difference with the 911 is they're not stuffed under a hood with all the other heat generators, they're in an exposed area under the car.
Old Mar 12, 2009 | 11:20 AM
jimmer23's Avatar
Yep. I changed my oil often, always cooled them down, made sure that my AFR were ok, and had huge intercoolers and insulated dual snorkel ram-air keeping both the intake and charge air cool. Worked for me...
Back to the OP - the stock turbos can take a lot of abuse, and I haven't heard of any failures.
Old Mar 12, 2009 | 02:10 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Wanna give us more info on your old setup? I'm very curious about it.
Old Mar 12, 2009 | 05:47 PM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Jimmer, me too! Please tell us more about your setup. Did you have intercoolers? What kind of AFR gauge did you use? What kind of boost controller; or did you just turn the actuator nuts forward? What are the options on the wastegate springs?
I don't have money to do many upgrades, and I also kind of like the idea of maxing out the K16's as much as I can.
Sorry for all the questions,
Ryan
Old Mar 12, 2009 | 06:25 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
NO boost for you(in the soup **** voice)
Old Mar 13, 2009 | 11:23 AM
Scottslaw's Avatar
Scottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond reputeScottslaw has a reputation beyond repute
I haven't heard of any Turbos going on these cars yet. I'm actually surprised myself. Maybe it's because not many ppl over boost them as much as the average turbo car. Most of the common turbo cars like Talons.. Supras... sr20det's blow often but most of them run much higher boost than stock maybe?
I was replacing my spark plugs and noticed oil on my drivers side intercooler piping? So maybe mine's going? is that a sign that my seals are going?
I noticed the same thing when I first got my car. I had a loose connection. Make sure the i.cooler hoses are all firmly seated and that the wire circle clips are "clicked" in. Oil in this area is pretty normal from what I hear. scott.
Old Mar 13, 2009 | 05:26 PM
911rox's Avatar
911rox is infamous around these parts
As stated above, it is normal to have some oil in the induction pipes, especially noticed with turbos as the forced induction can make it weap... Just tighten the clamps on the piping to ensure you don't have any leaks... The presence of oil with turbos is bad when its coming from your exhaust....
COBB Tuning
Jan 1, 2025 09:02 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
SharkyShark20
Sep 19, 2015 09:54 PM
Vrseis
Aug 20, 2015 07:41 AM
