Question on A/F ratio
Old Mar 20, 2009 | 11:23 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
So, I datalogged my car , after the MAF cleaning, on my way home from work, about 30 minutes worth of driving in stop and go traffic and getting on it on a highway. The afr looks really solid around 14.7, but on several occasions when I look at the log I see it go to 60 or 50 a few times, looking at rpm it might be doring shifts and or decelleration, is this normal?
Old Mar 20, 2009 | 11:30 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Your AFR's will go lean when you back off the accelerator...if you're watching your gauge and you hit it hard and go WOT, you should see the AFR's go into the 12-13 range for a bit while at WOT....back off the accelerator, and it goes lean again. I've never seen it go 60....mostly 17-20....but it'll run at 14.5-9 while just cruising or at idle.
Old Mar 21, 2009 | 12:41 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Totally normal. It will bob up and down across the spectrum at idle and normal cruising speeds. At WOT though, the ECU goes into closed-loop mode and should peg at around 12.
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
turbotuner20v
Sep 11, 2015 12:02 PM
The Oss
Aug 24, 2015 08:19 PM
