Anyone know if 997 tiptronic will fit in a 996 turbo?
Old Mar 28, 2009 | 09:44 PM
  #31
996flyer's Avatar
996flyer has a spectacular aura about996flyer has a spectacular aura about996flyer has a spectacular aura about
Originally Posted by RickEager@***.n
The limp mode is a hard fault. You can take your battery cables loose and touch them together for 15 minutes and that will clear the limp mode. I would advise looking at your throttle body Throttle Positioning Switch which is why my car went into limp mode and that's how I cleared the fault.
yes we have tryed this and even had the porsche dealer try to clear it and they couldnt because that is how bad the transmission is messed up
Old Mar 29, 2009 | 06:16 AM
  #32
ttboost's Avatar
Seeing as you are stepping up to a new tranny, take this opportunity to install an UPGRADED torque converter NOW. Mods or not, your tranny will thank you.
Old Mar 29, 2009 | 08:36 AM
  #33
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Have you tried re-setting the adaption values through the ECU?
Old Mar 29, 2009 | 08:37 AM
  #34
Have you tried a different Control module unit?
Old Mar 29, 2009 | 10:22 AM
  #35
996flyer's Avatar
yes we tried that while it was at the porsche dealer and did not make a difference
Old Mar 29, 2009 | 08:48 PM
  #36
996flyer's Avatar
thank you for your input
Old Mar 30, 2009 | 03:21 PM
  #37
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Its probably the flux capacitor.
Old Mar 30, 2009 | 04:53 PM
  #38
Ken's Avatar
Ken
Ken is a jewel in the roughKen is a jewel in the roughKen is a jewel in the roughKen is a jewel in the rough
An upgraded torque converter is $4K when the whole transmission is $8400. Labor for the transmission install is ~$2k. If you have to break down the transmission for the torque converter, double it.
Food for thought
Old Mar 30, 2009 | 05:04 PM
  #39
Did they swap it for the latest version (control module)?
Old Mar 30, 2009 | 05:49 PM
  #40
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Food for thought
Ken, please check your PM.
Old Mar 30, 2009 | 05:50 PM
  #41
996flyer's Avatar
yes and it made absolutely no difference
Old Mar 30, 2009 | 07:09 PM
  #42
Ken's Avatar
Ken
It usually takes something pretty violent to hurt the control module - it's a PCB and fairly rugged.
Old Mar 30, 2009 | 07:18 PM
  #43
Ken's Avatar
Ken
I think there was a different transmission in 2002, but, if not,
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessoriesCould save you a few dollars.
Old Mar 30, 2009 | 08:31 PM
  #44
996flyer's Avatar
well we decided to rebuild it and that is alot cheaper than getting a new transmission and it will have all 997 internals in the transmission so it will be a much better set up
Old Mar 30, 2009 | 09:06 PM
  #45
Ken's Avatar
Ken
good luck - post the results
