why do turbos use oil?
Old Oct 11, 2004 | 04:31 AM
4carl's Avatar
4carl is infamous around these parts
Most turbos use about a quart in 1-1.5k mi.. Is it being burned in the cylinders or is it lost in the turbo seals? thanks carl
Old Oct 11, 2004 | 04:38 AM
Moogle's Avatar
Moogle is infamous around these parts
i believe it is being used by the ball bearings and other areas inside the turbo that require lubrication.
Old Oct 11, 2004 | 04:54 AM
4carl's Avatar
The standard turbos do not have ball bearings.
Old Oct 11, 2004 | 05:15 AM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
Lube, and cooling.
Old Oct 11, 2004 | 10:13 PM
4carl's Avatar
My GT3 does not use any oil and the GT2 uses about a qt in 1200 mi. The 2 is lower reving and the same basic engine. If it is the turbos where is it being burned?
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
Lucid Moment
Aug 20, 2015 02:22 PM
