Why is Oil dripping out of compressor housing on stock k16 turbos into intercooler?
Old Apr 26, 2009 | 04:01 PM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
It's obviously normal to have a little oil but a good amount all of a sudden dripping into the compressor housing from I believe the intake is very very strange as I was filling the car up with oil?
What makes this strange is I was doing spark plugs today and figured I'd change the oil too at the same time since I was under the car. I had the intercoolers off and a perfect view of the turbo's. I poured in about 7 quarts without chaning the oil filter and was planning on filling it up as the car warmed up. As soon as i get done filling the car oil on the DRIVERS side turbo oil had a handful oil dripping out of the compressor housing since the intercooler was off, it would have pooled up there if the intercooler was on the car.
So possible caused of oil coming out of turbo:
some kind of bad PCV/oil separator valve
I'm confused and its not coming fromt he intake but the actual oil seals on the turbo. The compressor side of the turbo has bad oil seals and somehow just by filling the car with oil it leaks out of the compressor.
maybe it's completely normal...car runs perfect and doesn't leak, or burn oil besides the very small normal amount for Porsche turbos. It's a stock k16 turbos with a EPL flash and straight pipes.
Any opinions would be great.
Old Apr 26, 2009 | 04:03 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Did you drain oil from both the oil sump tank and the crank case?
I think you may have overfilled the oil.
Old Apr 26, 2009 | 04:58 PM
turbo turbo's Avatar
turbo turbo is infamous around these parts
this happend to me too. my case was that i put to much oil in. i drained the oil, put new oil in,right amout this time, problem solved. i other thing when i started it smoked for awile till it burnt the oil off in the turbos..
Old Apr 26, 2009 | 06:06 PM
LamboTT's Avatar
rear drain plug and turbos. dont think I overfilled it since I drained everything and added may 7-7.75 qts at the most
Old Apr 26, 2009 | 06:22 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
I think you missed draining the oil tank(by passeger rear wheel) which would mean you overfilled by about 4-5 qts
Old Apr 26, 2009 | 07:19 PM
LamboTT's Avatar
Bingo! I've only had the car a couple months and did one oil change. I forgot about the oil tank on the passenger side even though I did it last time. I guess no harm, especially since I didn't even turn it on. 6Speeders comes through! Thanks.
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
SharkyShark20
Sep 19, 2015 09:54 PM
Vrseis
Aug 20, 2015 07:41 AM
