Brake fluid swapping
Old Apr 28, 2009 | 05:24 AM
scott's Avatar
scott is infamous around these parts
Are there any concerns going between ATE and Motul fluid from event to event? I'm using ATE this time. I'm told the boiling point is only a few degrees lower than Motul and it's cheaper. Any issues if I go to Motul for the next event?
Old Apr 28, 2009 | 11:09 AM
j.mitchell70's Avatar
j.mitchell70 is infamous around these parts
Would like to hear this as well. Also, sort of off topic, but does anyone know if they make a fitting for the Motiv bleader specific to the Porsche? Thanks
Old Apr 28, 2009 | 02:54 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
These are both DOT 4 fluids, and should be completely compatible. I have done this swap myself. It is convenient to have the color change to know when the line has been completely replaced.
These days I use the Motul exclusively and count the number of times I pump the pedal to clear the line. 10-12 for the rears, 5-6 for the fronts.
Jon
Old Apr 28, 2009 | 06:08 PM
scott's Avatar
Jon,
Thanks. Good to know as I was told that you shouldn't go from something like Motul back to OEM fluid. Don't know if that's true or not.
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
ModBargains
Oct 13, 2015 03:45 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
