First trip to dragstrip....any tips?
Old May 19, 2009 | 12:24 PM
BlueFVD-575's Avatar
BlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to behold
Thanks for the advice from titan. Im sure it'll take me a few tries to get it right. I'll post my times tomorrow.
Old May 19, 2009 | 12:47 PM
GARY J's Avatar
GARY J is infamous around these parts
Good info. Thanks for the heads up.
Old May 19, 2009 | 01:09 PM
hrs1's Avatar
hrs1 is infamous around these parts
Originally Posted by onelove
No negative energy, if anything I like drag racing the 996tt as much as anyone. Which clutch is in the car determines the first part of the track as much as anything . With a stock clutch you can launch the car VERY hard, however you will be looking at replacing it very soon.
Turn the PSM off for drag racing. Check your tire pressure, make sure they're consistent across the board and drop the rears to around 30-32psi hot (you will likely need to play with this depending on the tire you have on the car). Skip the water box completely and do a quick pre-launch to shake any debris off the tires before heading up to the line. Again with AWD you want absolutely no water on the tire when you enter the tree. I would suggest starting around 4500rpm and slipping the clutch quite a ton to prevent wheel hop, if you feel the slightest hint of wheel hop ease off the gas and be ready to short shift. Depending on your powerband you will want to shift a bit before red line, when you fee the car starting to accelerate slower towards the top, make a shift into the next gear as quickly as possible, and stay in 4th through the traps.
Clutch slipping is the key to getting a good 60foot, on street tires I'd say if you can hit a 1.7-1.8 your first time our you should be very happy. On the stock clutch and tires we where able to get a 1.61 60ft launching at around 6500rpms, however if a new clutch isn't in your future I wouldn't suggest this.
SPOT ON! I know this sounds silly but dont let off accelerator until you know you passed the end of 1/4 mile
Old May 19, 2009 | 01:18 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Pull fuse B9 to completely disable PSM. Drop your tire pressures to 24psi all around to minimize hop and maximize traction. Avoid the water at all costs, and do a quick burnout to get rid of any you may have tracked into. Dump the clutch at 4k rpm and progressively get into the throttle in 1st. Then concentrate on hitting every shift - I had the most success short-shifting at 6k rpm with K16s.
With the stock clutch and ~575hp, you'll likely burn it out...
Old May 19, 2009 | 01:24 PM
ttboost's Avatar
Good Luck!!! For a rear engined car with big tires and some power they are NOT great drag cars, stock. Take everyones advice here, and most importantly, keep your expectations low...
Old May 19, 2009 | 08:29 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Don't listen to Mike, they are great drag cars You just have to learn how to punch the hell out of them
Old May 20, 2009 | 02:17 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Great advise Wes & jimmer23.
What can one expect to run with a 02-03 6MT/Bone Stock 996TT on street tires; i'm talking about a avid drag racer? Thanks!
Old May 20, 2009 | 06:58 AM
MBailey's Avatar
If you really hit it perfectly I think an 11.9-12.2s are possible with good conditions in a stock car.
Old May 20, 2009 | 07:38 AM
Prche951's Avatar
Don't be to concerned with your time. The trap speed tells all.
I do want to add that the place where you will gain or loose is in the shifting. When there is no load on the engine (During shifting), boost drops and has to build up again, the quicker you shift, the less boost you loose between shifts and the faster you will go. If you have a stock clutch, I would not recommend hammering off the line. Roll out like everyone says. you will loose about half a second because of it, but you will drive home at the end of the night.
Hence the reason why auto trannies are usually faster in acceleration than stickshifts in the same car.
Old May 20, 2009 | 08:33 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Bone stock, with the rear seat removed we where able to get a 11.79 @ 116 with a 1.61 60' on PS2s
Trap time does tell most of the story, however at the same time will very quite a few MPH from a proper traction pass, and an "easy" pass.
Old May 20, 2009 | 11:31 AM
Prche951's Avatar
that is excellent on street tires. But bone stock you probably don't spin them much. I cannot get traction in the first 3 gears in cold weather and in hotter weather I can't traction in the first 2. I have PS2's.
Believe it or not, trap speed won't change much regardless of your 60ft time. Only your ET will change. I have had times that varied by a full second and my trap speed varied by half a mph.
Old May 20, 2009 | 11:39 AM
albuht813's Avatar
albuht813 is infamous around these parts
wow. some really great tips here.
Old May 20, 2009 | 12:18 PM
jimmer23's Avatar
That's an insane 60' time. If he can get down into the 1.7's he should just crack 12's stock. Not easy on street tires for sure. Practice practice practice! Find an empty lot one weekend and just launch.
What are the exact mods on this kit (OP)?
Old May 20, 2009 | 03:28 PM
k-ore's Avatar
Wes,
Great info again. Sorry for the thread hijack, but does TMS plan to debut the turbo inlet pipes for the 996tt; I saw you folks made a custom set for the camo 996tt?
Thanks!
-Val T.
Old May 20, 2009 | 03:38 PM
onelove's Avatar
Wes,
Thanks!
-Val T.
Not sure if we'll make it a production piece or not in the future. They're real tight radius bends and not something we could easily make in 1 bend like other pipes. Once we finalize our move it may be more of a possibility, but definitely not something we'll have available in the next 2-3 month. Also keep in mind we converted to speed density, it would be up the individual tuner to make the setup work otherwise.
-Wes
