Car launching for drag racing?
Old May 28, 2009 | 06:08 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
Nice trap speed Justin
Old May 28, 2009 | 08:06 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Originally Posted by PALETTE
Wes are you running stock Axels?
How are you finding the launch with the RWD conversion?
I have contemplated it but not convienced yet
We are running Drive Shaft Shop upgraded axles, as well as a Guard differential. We went RWD after installing the Guard, with the diff the car definitely seemed to go straighter, still working on the traction issues. With RWD only the R compounds defiantly did not hook as well as AWD, going to try a stickier tire and see if we can't get some better results RWD only.
Old May 28, 2009 | 04:10 PM
ttboost's Avatar
Wes, Did you guys break axles or was it a preventative measure? Just curious if they did break at what RPM and how? I know cars are different, but this would help me decide how to drive my car at the strip, until I upgrade axles too.
Old May 28, 2009 | 04:57 PM
Prche951's Avatar
good question. Lets see what comes back
But I know a turbo up here that laid waste to it's axles and it had a launch control at 4400 rpm I think. It also had racing slicks so it hooked while it hopped right in the middle of it's maximum torque (3500-4500) and bam!. I want to do launch control of 4000 rpm, but this is what worries me. that is a huge load on the axles.
Old May 28, 2009 | 05:10 PM
ttboost's Avatar
My 2 step is set at 4k also. My clutch is not very "slippable" so I am afraid that trying to "slide" it out while flat-footed, I might end up dumping it at 4k and have to push it back in the trailer....
Old May 28, 2009 | 05:16 PM
Prche951's Avatar
my new clutch won't be slippable at all either, so I might consider a lower launch rpm like 3200-3400, just under max torque.
Old May 28, 2009 | 05:23 PM
ttboost's Avatar
Yeah... tried that... 2.0-2.1 60'...slightly less than impressive for ET's but likely won't break anything...got a track rental on 6/12...might be able to hot lap and practice launching...
Old May 28, 2009 | 05:30 PM
Prche951's Avatar
that 60ft time is about the same as rolling off the line. Well, the best 60ft times I have seen in these cars seems to be 1.6. So half a second lost basically.
Old May 28, 2009 | 05:35 PM
ttboost's Avatar
...which is a full second on the big end..which is about right for my power level...
Old May 28, 2009 | 05:41 PM
Prche951's Avatar
what was your et and speed?
Old May 28, 2009 | 05:47 PM
ttboost's Avatar
best pass of the day on my 1st time out. (left lane #109) This was a really bad 2-3 shift also, so room for improvement. Timeslip hardly representative of my 60-130...
Old May 28, 2009 | 05:50 PM
Prche951's Avatar
your trap speed kicks ***. So I'd say that you should have been in the high 10's. you are almost at 130 mph. I noticed your 60-130 is incredible.
Old May 28, 2009 | 05:53 PM
ttboost's Avatar
Going back soon. Fixed a couple of things, so I'm gonna try to improve on both ET and MPH. Might try some more 60-130's this weekend.
Old May 28, 2009 | 05:57 PM
Prche951's Avatar
still got your spare in the car? take it out!!!!
Old May 28, 2009 | 06:02 PM
ttboost's Avatar
Spare tire, jack, tools and compressor come out. Meth kit probably adds 10lbs back in...Still AWD though.
