Ride-height
Old Jun 8, 2009 | 04:24 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Ride-height
Ok guys searched but no definitive answer.
What is a stock ride height for a non US spec car to start with? - to fender lip.
What is best compromise ride height you recommend for the street?
As you know I’ve had H&R lowering springs, now I have PSS10’s ready to be installed.
What shall I set my ride height to (front/rear) no rubbing? - to fender lip?
Old Jun 8, 2009 | 06:56 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
The only data I've seen referring to a Euro car (I believe it was a PCA Panorama article), all measurements to fender lip through center of the wheel),
C2 Euro M030 25 1/4 (666 mm)
Stock US Turbo 26 3/4"
Stock US Gt2 25 1/4" (642 mm)
You need to define some more parameters; stock wheel & tires (tire make), aftermarket, standard or modified camber ect? Other Euro guys can chime in on what they have; I personally think just below the GT2 (25"?) is the low end for day to day use in the US if you have the lip clearance.
Hope this spurs conversation & gets you more local data.
Old Jun 8, 2009 | 08:38 AM
Terminator's Avatar
You are right. Thanks. So, more specifically I just measured my height; front: 25.11 inches (638mm) passenger side and 25.39 inches (645mm) driver’s side, rear: 25 inches (628mm) and 24.72 inches (635mm) respectively. Brand new Pirelli P-0-Rosso’s, stock wheels, tyre sizes and stock alignment. So, what’s the general consensus? Should it be same all way round? Or slightly lower at the front/back?
Jul 29, 2019 11:13 AM
PelicanParts.com
Jun 3, 2015 02:06 PM
Mike@Renntech
Apr 18, 2014 01:18 PM
4Thirty
Cayenne 955/957
24
Apr 27, 2008 04:05 PM
