Are engine internals the same for the turbo and GT2?
Old Jul 8, 2009 | 04:31 AM
landjet's Avatar
The reason I'm asking is eventually I want to upgrade to K24's of some kind and am wondering if a regular turbo will support that.
Old Jul 8, 2009 | 05:29 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Running the k24/18g set-up on my car with no internals done. These are really strong motors and if you don't go crazy with the boost they will take a lot of HP and still last a long time.
We still need to swap rides
Old Jul 8, 2009 | 06:16 AM
wross996TT's Avatar
while they are basically the same there are different part numbers (don't know what is physically different) for:
cylinders/pistons
oil pump
tranny cooler
other stuff:
some lines/hoses
ICs
air ducts
fuel pump
muffler
clutch spring/master cylinder
intake manifold
Old Jul 8, 2009 | 07:18 AM
Prche951's Avatar
upgrade away, it's the exact same engine. The major difference is the K24's, tuning, turbo intake tubes are bigger, reportedly, and larger IC's (called GT2 ic's). Of course there are more diferences than that, but for your purposes that is it.
Old Jul 8, 2009 | 04:40 PM
Kato's Avatar
Kato is just really niceKato is just really niceKato is just really niceKato is just really niceKato is just really nice
Same motor...just some slight changes to parts around it is my understanding.
Old Jul 8, 2009 | 05:01 PM
sharkster's Avatar
Built a few so as far as the motor goes there are a couple of key differences... The gt2 uses a GT3-R oil pump with a secondary pick up being the major diff....
Old Jul 8, 2009 | 05:36 PM
unvmy996's Avatar
sharky is the gt3 oil pump with secondaty pick up realy needed if you dont track the car ?
Old Jul 8, 2009 | 05:41 PM
cjv's Avatar
cjv
Moderator
On hard cornering or hard off the line starts the stock turbo pump is not sufficient.
Old Jul 8, 2009 | 07:36 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
I think the GT2 has different cams too.
Old Jul 9, 2009 | 07:44 AM
WOODTSTER's Avatar
Same cams.
Remember that the X-50 package came with K-24's so if your original question is
will the block of a standard 996 TT (K16) be able to withstand the mad Power from
some K-24's...the answer is yes.
MK
Old Jul 9, 2009 | 07:47 AM
Prche951's Avatar
I have been told that the cams are the same just the cam timing was just locked wide open on the GT2(more duration), making it less tractable but making more power. This can be done to the tt as well. This is what I remember hearing. but who knows
Old Jul 9, 2009 | 07:48 AM
WOODTSTER's Avatar
cylinders/pistons
oil pump
tranny cooler
other stuff:
some lines/hoses
ICs
air ducts
fuel pump
muffler
intake manifold
Wross, correct me if I am wrong but sometimes different part numbers can
be the exact same parts (I have run into this on some replacement parts on my car)
I do not believe that that the pistons, heads, cams or anything other than
the oil pump and transmission cooler are different.
MK
MK
Old Jul 9, 2009 | 08:31 AM
911-AL's Avatar
911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !911-AL Is a GOD !
Good to know.
Old Jul 9, 2009 | 02:57 PM
cjv's Avatar
cjv
Moderator
MK
MK
Woodster,
You are assuming correctly. internal motor wise the only difference is the oil pump and it's pickups. The pump is higher volume and the additional pickup adds to the protection from oil starvation with tracking and fast accelerations.
TrackOne
Aug 20, 2015 12:56 PM
Vrseis
Aug 20, 2015 07:41 AM
