Rear Wheel Rim size?
Old Oct 30, 2004 | 10:47 PM
DarioTexas's Avatar
Senior Member
DarioTexas is just really niceDarioTexas is just really niceDarioTexas is just really niceDarioTexas is just really nice
Will there be a significant difference ... or what is the difference between gettting 11 inch rears VS. 11.5 inch rears? is it just the looks .... does the wheel look sunk into the car or is there no diff. at all?
Dario
Old Oct 31, 2004 | 12:37 AM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
The difference in rim width will be small, but the look on the car will all depend on the offset.
Old Oct 31, 2004 | 01:29 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
As mentioned, position of the rim or tire wall relative to the fender is generally considered to be a function of offset (ET which means 'pushed in'). An 11.5J rim would have to have 5-6mm less offset in order to look exactly the same (fender line) as an 11J.
You are splitting hairs here.........but you may want to check the rim width is proper or ideal for the tire you want to run.
PenguiN
Nov 12, 2015 05:24 PM
Sep 1, 2015 03:16 PM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
cab83_750
Aug 19, 2015 12:37 PM
