"Missing" at WOT
Old Oct 31, 2004 | 11:58 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
"Missing" at WOT
Tonight while making a WOT run in 3rd gear as the rpm passed ~4000 rpm the engine started missing; nothing "hard", just a very slight sputtering kind of miss with power not quite as strong as before. I shifted to 4th and at WOT it did the same thing. I slowed down and repeated the 3rd gear run except at just less than WOT, and the power was strong and there was no missing. I tried WOT 3rd gear pulls a couple of more times with the same results. All subsequent 1st and 2nd gear pulls (WOT) were smooth as silk.
Could it be my plugs? They have ~17k on them (OEM). The gas is from the same station I always use and is 93 octane. I did have a few 3rd gear pulls behave normally later in the drive, but the last one I did missed again. So the bottom line is it's doing this "missing" intermittently in 3rd and 4th gears at 4000 rpm and above, with 1st and 2nd gears never showing any problems.
Old Oct 31, 2004 | 12:15 PM
ChrisNJ's Avatar
ChrisNJ is infamous around these parts
I would suggest checking(clean or replace if necessary) and regapping your plugs.
Old Oct 31, 2004 | 01:21 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Dock,
I had identical symptoms @ 23,000 miles and the problem was spark plugs. The best part about doing the service is that the car ran stronger at all RPM's with the new plugs.
FYI - My plugs were destroyed at 23,000 miles.
Old Oct 31, 2004 | 01:53 PM
Chris & John - Thanks for the info. I did a search on the Forum checking on previous posts by owners who had similar problems. It looks like plugs are the best place to start. I hope it's something easy like that. And like John said, more power wouldn't be a bad thing either...
Old Oct 31, 2004 | 09:32 PM
MKW's Avatar
MKW
MKW is infamous around these parts
That could also be a warning sign that you are about to experience the car's well known tendency to disconnect it's fuel lines inside the tank area - ask me how I know .
Old Nov 1, 2004 | 04:23 AM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
It's plugs (and possibly a particular cyl. coil pack)-- do it a few more times and you'll trigger a CEL. The code will read engine misfire -- I'm betting it's cylinder #3.
Old Nov 1, 2004 | 05:05 AM
Lizard1's Avatar
Lizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of light
How oftern should you change your plugs? I think it's part of the 30K mile service but if not, when do y'all suggest I change them. I'm very proactive in maintenance even if some view it's a waste of $$$
thanks in advance
Old Nov 1, 2004 | 07:19 AM
ChrisNJ's Avatar
thanks in advance
I change my plugs at least once a year, and I only drive apprx 5-6k a year.
Old Nov 2, 2004 | 06:24 AM
Originally posted by Ruiner
I remember there being a "plug change guide" on here, but I can't find it anymore. Would someone mind posting it back up?
Are you thinking about changing the plugs yourself? If so, give me a call and we can do both our cars together.
Old Nov 2, 2004 | 07:31 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Damn, that sound's like fun...A plug changing party!!! :=)
Old Nov 2, 2004 | 07:33 AM
rockitman's Avatar
By the way, there are detailed plug change instructions by Loren over on RennTech available to contributing members in the 996 DIY section. fyi
Old Nov 2, 2004 | 08:25 AM
All I found over there were instructions on how to do the change on the 996. The Turbo has a few more parts to pull...right?
Old Nov 2, 2004 | 10:07 AM
rockitman's Avatar
Yes, it is different but the general idea is the same. KPV should weigh in on this. I know he did it himself not too long ago...
Old Nov 2, 2004 | 10:18 AM
Lizard1's Avatar
shoot me an email when you do this, I'd like to partake
Old Nov 2, 2004 | 10:28 AM
Will do. It will be in the next couple of weeks.
