anyone tried these sensibly priced headers. (Not Chinese)
Those look Chinese... inferior materials, welding, etc.... all grinded down and coated to look good.
These are what headers look like that are made of thick walled(insulated) steel. These are the first set of Boost Logic headers that I have been helping with the R and D on over the last 6 months or so, and therefore, not a production unit(test only). This is the look you want to see in a non-factory header and keep in mind that this is not even a production set.
That thin walled chinese crap is prone to cracking, breaking, leaking, etc. Keep it stock if you are thinking about those Schnell headers.
Justin
Justin
The PET number (part number) is the same for the 996tt (both),
and GT2. I also know of no difference in the cats or exhaust...
Odd about that brochure... I'm not an expert in the X50 option,
but I believe all it is, is the k24 and the programming required
for it, though they may get the steel syncros in the tranny too.
Joe, you are correct, 996GT2, TT, X50TT all share the same headers. Same engine components, same intake plenum. I guess the factory headers are pretty darn good.
are there any verified dyno graphs on stock k16 and k24 cars to show an improvement in power?
Interesting. So that's a little loss from idle up to 3400rpm,
then a little gain up to about 4400, then a significant gain up
to about 6000, then back to about the same...
And is that with no other change at all? I'd be interested
in any new data for 996tts, and yes the VVT might be making
a difference because of the increased upper flow. What diameter
headers were these?
headers were these?
Well, from what I hear from the best tuners around, headers *don't* help
at all, and actually hurt (max power and power under the curve) cars without
significantly bigger-flowing motors than stock. And these are guys trying to
earn my money by maximizing my power-under-the curve.
That curve makes sense. you loose power at lower flow, then you gain power the higher up you go. Seems like at a certain point the header curve really keeps the power and torque level, where the factory headers drop off. I presume these were stock cars. I'd bet ported headers would give similar results.
I can say that my beautiful custom(not chinese made) headers removed about 50% of the drone I had before. Car is louder, but has less drone, so that is one positive aside from possible power gain.
Serg124
Sep 10, 2015 05:27 AM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
oddjob142
Aug 19, 2015 12:27 PM
