Drivers window malfunction...
Old Aug 14, 2009 | 09:35 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Normal operation of window is to lower a bit when door is open and then close when door is closed...Now when i open the door it lowers but it goes up again when door handle (in or out) is released...So i have to lower the window with the switch in order to close the door...Any ideas?
Old Aug 14, 2009 | 12:18 PM
Prche951's Avatar
Yes, I was told this was a $500 fix. it's cheaper to lower the window then raise it
Old Aug 14, 2009 | 12:24 PM
toppower's Avatar
toppower is infamous around these parts
+1 $500 fix....
You might be able to reset the window....check online of service bullitins
Old Aug 14, 2009 | 01:26 PM
Thanks for the info...$500fix...Wondow operates fine no part open or close...just this matter...I am sure it should be some kind of microswitch broken...So i will try a DIY in the future days...Anyone done this?
Old Aug 14, 2009 | 01:34 PM
toppower's Avatar
Might have something to do with a stretched cable???
Old Aug 14, 2009 | 02:20 PM
I do not think so...window was fine until it just wont stay down to close the door...
Old Aug 14, 2009 | 06:03 PM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
i have the same problem ! when i open the car for exterior the windows goes down but after i release the door handle it goes up so before i close the door i lower the windows just a little bit.
500$ for this i will not pay ! )
Old Aug 15, 2009 | 12:37 AM
Guys i will do a DIY next days to fix it...in order to save $500 for me and for others...
Old Aug 15, 2009 | 01:52 AM
alex55's Avatar
good luck !!!
don't forget to take pics !
Old Aug 15, 2009 | 02:15 PM
David C's Avatar
David C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to all
Related window operation question
A somewhat related question:
The normal window-door operation is explained above and known to all of us with 996tt's. Additionally most of us know that if the battery loses charge we can introduce current through a location on the fuse block to open the trunk to access, and charge, the battery.
If the door is locked, the window closed, and there is no charge in the battery how can the fuse block be accessed? The door can be unlocked with the key but what powers the window down to allow the door to fully open. Remember the window is normally up and trapped in the black channel that is fixed to the body.
Thanks for the answer.
Old Aug 16, 2009 | 02:59 AM
Worst case scenario is to have all doors and windows closed and open the front hood,disconnect the battery and close the hood...Even though i believe that after you unlock the door and lift the handle the door will open even if the window stays full up...On the other hand closing the door is impossible without lowering the window...Two days now after i my attempt to close the door and hear the "gap" sound i remember to lower first the window...Stupid microswitches...It seems that each door has 3 microswitches...One for outer handle,one for inner handle and one to identify if the door is open or close...The later is the most expensine while the others cost only a few bucks...
Old Aug 19, 2009 | 11:35 PM
SAVED4IT's Avatar
SAVED4IT is infamous around these parts
This same window issue was on my 996. I had an extended warranty that sucked up the cost. I think it's a pretty common issue.
Old Jun 19, 2010 | 08:33 PM
Gixxed_Spyder's Avatar
Gixxed_Spyder is infamous around these parts
Question Figure it out yet?
Were you able to figure this out? I'm now having the same issue. Before I close the door i have to lift the door handle a bit so the window lowers a 1/4" then close the door then let go of the handle. It's PITA...Tell me you have a solution outside of the $500 stealer option.
Old Jun 20, 2010 | 01:55 AM
alex55's Avatar
Old Jun 20, 2010 | 02:17 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I would start with the battery low option. It could be a signal to the driver that you are not getting a fully charged battery and we are just overlooking information programmed into the ECU for our benifit.
