Fuel Pressure Regulator Upgrade Question
Old Nov 9, 2004 | 02:30 PM
StephenTi's Avatar
StephenTi is infamous around these parts
Gonna inject some inexpensive safety margin to my setup, and crank up the fuel line pressure up a tad... any suggestions/experience to share?
What's the stock fpr regulate the pressure at?
I'm looking into the GT3 RS fpr (same as Porsche Motorsport?) per a friend's suggestion... I believe it's a 5 BAR regulator.
What's involved in swapping out the regulator?
Thanks,
Stephen
Old Nov 9, 2004 | 11:44 PM
ebaker's Avatar
ebaker is infamous around these parts
It seems like raising the fuel pressure would require a total remapping of the ECU, including ALL the part throttle and cruise settings.
Old Nov 10, 2004 | 02:05 AM
AMG ETR's Avatar
As Kevin said, we usually have a good amount of these instock. We require them on our Level 4 kit (which is 575BHP) so if you are anywhere near or over that it is a good idea!! Like Kevin said its cheap insurance. Also as Kevin said, it is a ***** to install, but our tech gets um done in 10-15 mins.
Evan
Old Nov 10, 2004 | 03:50 AM
StephenTi's Avatar
Thanks for the input, everyone.
ebaker:
Yes, I think the mapping will be a little off, but no so much so that the automatic closed-loop learning of the ECU will be out of it's range.
In other words, once the fuel pressure is raised slightly, the ECU will simply adjust the injector pulses down to shoot for the pre-set A/F ratio. This is usually how it works.
Any thoughts?
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
turbotuner20v
Sep 11, 2015 12:02 PM
tkebp1275
Aug 31, 2015 06:35 PM
The Oss
Aug 24, 2015 08:19 PM
