Location for XM antenna?
Old Aug 25, 2009 | 12:52 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
Where do you guys with XM radio place the antenna?
I used the original NAV antenna location in the front center of the dash for the NAV antenna but had pretty bad reception with the XM radio antenna in the same location.
I also tried different locations under the dash with the same poor result. The radio just fades in and out too much.
I have been driving around with the antenna visible on the exterior of the car for a while now. Reception is great but the look bothers me.
Any ideas?
Old Aug 25, 2009 | 02:19 PM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
I was going to put it next to the Nav, like you did, but now I won't. What about on the rear parcel "shelf"?
Old Aug 25, 2009 | 08:40 PM
ABCar's Avatar
ABCar is infamous around these parts
It needs to be on the outside for good reception. The roof is good. It can go on the rear window at the top or bottom center near the edge. It wll probably visually "go away" after a while. I have had them on about four cars and the xm is worth the visual comprimise imo.
jaehoppa
Oct 22, 2015 09:17 PM
tjj7ff
Macan
Sep 6, 2015 06:45 AM
