Porsche Charge Pressure Sensor 996-606-180-00 spec?
Anyone know what the actual part number of this is from Bosch? I am trying to find out what is it electrically.
1) Max Pressure, is it a 1 bar MAP? or a 2 Bar MAP Sensor?
2) Is it a standard 5v unit?
3) I would like the formular to calculate the pressure/volt output or at lease a graph showing it.
Any help would be appreciated,
SWR
SWR
Well I found out some more information on Porsche MAP Sensor (Charge Pressure Sensor)
Bosch Part Number: 0 261 230 042.
It has a pressure range of 20-250 kPa it also has a NTC sensor built in with a range of -40* to +130*C.
Electrical connections are Pin 1 = ground, Pin 2 = NTC resistor, Pin 3 = +5VDC , Pin 4 = Boost signal.
It is a 2.5 Bar 5 Volt DC Sensor. 1 Bar Ambient and 1.5 Bar Absolute.
joseph_number1
07-19-2018 05:45 PM
PenguiN
09-15-2015 11:44 AM
Nissan GTR
08-19-2015 02:11 PM
