Epl flash loader help!
Old Sep 7, 2009 | 09:02 AM
SIC996's Avatar
SIC996 is infamous around these parts
Trying to install the tune into my car and it will not start!! any help from someone that has done this or if Tony is on here can you call Clint at the shop
Old Sep 7, 2009 | 09:14 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Clint's flash loading tool hasnt made any attempts for connect to the server.... Or hasn't yet successfully tried to flash.
If the cars not starting, it looks unrelated to the flash or flashloader.
Ill call Clint in a little while.
FYI - We are closed today and will be back in the shop tomorrow.
Old Sep 7, 2009 | 12:09 PM
SIC996's Avatar
Tony thanks again for calling on your holiday. Ill check the computer on my end.
Old Sep 7, 2009 | 09:20 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Re-install the USB cable drivers, I had this issue on my Macbook running a dual-boot version of XP. Also make sure once you re-install the drivers you remember the associated COM port it assigns to the USB cable. Once you've got that done it's a very straight forward automated process.
Oct 6, 2015 06:13 PM
Oct 2, 2015 02:23 PM
