Spacers and tire shops
Want to give the forum a heads up on an issue I had at Discount tire last night. I've been a repeat customer for a couple years, they know me and my cars well. I Went to get another set of rear tires last night (interestingly the wear is a perfect 2 rears for every 1 front with the Kumhos). I have the Porsche rear spacers and they balked at doing anywork whatsoever because company policy on "aftermarket spacers". It took a few minutes of telling them repeatedly and showing them on the porsche www that these are a Porsche part and factory option before they accepted that. No idea if its an actual factory option but cant imagine it wouldnt be.
They must have been burned recently, anyway, wanted to give folks with spacers a heads up. |
What size spacers are you using and are you still on stock wheels? Also, do you do any DE's with them on?
I get 2 rears sets for 1 fronts on Michelin PS2 as well. It seems like the norm. about 10Kmiles per set, in "normal" use.
22mm in the rear, I havent done any DE's this year but do drive somewhat "spirited" often.
Originally Posted by landjet
(Post 2536412)
I run 1" spacers on my otherwise stock acura TL . Im my experience spacers can significantly improve the handling of almost any car. They removed my spacers and put them in the trunk.
They said it was a liability. They suggested I add 10 lb or torque at each corner to make sure they didn't come loose. |
Anyone run spacers at the track?
What stories have you heard?
I've encountered the same "no spacers" policy at my local America's Tire, the sister chain to Discount Tire (same parent company.) Now I just take my wheels off in the garage and run them over to their store in my truck whenever I need them balanced.
(Post 2537231)
They give you a wider track, which reduces weight transfer. But I really doubt that it makes that much difference, at my skill level. I am very pleased to report that I have made 6 days on my current set of Michelin PSC's, and expect to get 3 more next month at Road America. That's the alignment, though, not the spacers. How do you like your new suspension setup? Jon |
Love it. I'm about to do the write up but still dialing it in. Think I destroyed one of my rear tires at VIR. Camber at 2.14 I believe in the back. 2.25 in front. Any suggestions?
Originally Posted by m5guy
(Post 2537417)
