roll cage question
Old Nov 18, 2004 | 12:00 AM
dlm477's Avatar
dlm477 is infamous around these parts
roll cage question
I have a custom sub enclosure in back of car. Will this be a problem if I install a roll cage? Also, any advice on how to get ecu out? Thanks. Dan.
Old Nov 18, 2004 | 12:02 AM
dlm477's Avatar
one more
Old Nov 18, 2004 | 02:18 AM
luting_chen's Avatar
luting_chen is infamous around these parts
i don't think it'll be a problem..
b/c cage mount to the lower part...
but u can only use the porsche TE cage
not the DAS or others...
Old Nov 18, 2004 | 02:26 AM
Curves4S's Avatar
Curves4S is infamous around these parts
the roll cages mount where the seat belts buckle in
Old Nov 18, 2004 | 09:33 AM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
A proper cage will tie into the rear strut mounts..... The box will need to go or at least be modified..........
If its a bolt in cage then you might be able to get away with it.
Jul 29, 2019 11:13 AM
Vellano Wheels
Other British Cars
Nov 25, 2015 08:57 PM
alevine
Nov 4, 2015 10:05 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Vellano Wheels
Other British Cars
Aug 26, 2015 11:06 AM
