PSM Module
Old Sep 19, 2009 | 12:10 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
you can trouble shoot it in place with a dealer computer
Old Sep 19, 2009 | 12:38 PM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
I had a similar issue. Simple MAF cleaning did not fix it. Replacing the MAF did.
What error codes are you getting on Durametric.
Don't have a Durametric code reader... get one or borrow one. No seripously best investment for these cars.
Old Sep 19, 2009 | 12:59 PM
jleeev's Avatar
jleeev is infamous around these parts
The computer is indicating a left front ABS sensor fault however I switched the left and right front sensors and fault still reading left side which leads me to believe that it may be a harness issue. MAF new with less than 2000 miles on it.
My indy advising that they would need to remove the ABS wiring harness in order to test.
Best,
J
Old Sep 19, 2009 | 01:01 PM
jleeev's Avatar
Best,
J
Old Sep 19, 2009 | 05:35 PM
Code 4460 - tested it and everything checked out harness, sensors bottom line Pump and module
Old Sep 23, 2009 | 06:31 AM
So I cleaned all the sensor, and reflashed the computer to see if there was a glitch in the programing that set off the code.... Its came on almost instant! as soon as i got the car moving it came on!!!! UGHHHHHH!!!!
Old Sep 23, 2009 | 08:43 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
Where the sensors really dirty Cory? Damn, I am sorry to hear that! So you think its the PSM module then?
Old Sep 23, 2009 | 02:28 PM
Ben the Sensors were not that bad to start off with so after a cleaning and assembly we spun the wheels on the lift and the light came on. Reset the computer and 2 seconds into a drive the light came on again!
I am telling you i know there are better places to spend $$ on but i do need to stop the car LOL
Old Sep 26, 2009 | 12:46 PM
BigBadBen's Avatar
Cory,
Guess what mine came back yesterday after I was messing around with my alignment issues. I have driven the car for well over 1K and nothing. The code that came up was Steering Wheel Sensor. I recalibrated the sensor with my Durametic Tool and am going for a boot in a minute to see if it comes back. It is very odd how this code pops up like this. I am still convinced there is nothing wrong.
Ben
Old Sep 26, 2009 | 01:21 PM
let me know Ben!! who did you recalibrate the sensor? did you just clear it?
Old Sep 26, 2009 | 05:20 PM
BigBadBen's Avatar
Just drove 200KM and all is perfect Cory. In the Durametric PSM module there is a setting that allows you to recalibrate the steering wheel sensor. Just click on it with the steering wheel straight ahead and it does it for you.
Ben
Old Sep 26, 2009 | 05:43 PM
Nice! Well i just cleared all the codes and cleaned the mass air and reset the battery as well i am going to drive it as soon as it stops raining here.
Old Sep 26, 2009 | 05:46 PM
BigBadBen's Avatar
Cory, Do you have a Durametric tool? if not you need one. I also have the Autoenginuity tool which is good but is not as good as the Durametric.
Old Sep 26, 2009 | 08:19 PM
Yes i do. I use it to clear my codes and Datalog
Old Sep 27, 2009 | 12:36 AM
BigBadBen's Avatar
So did you do the recalibration of the steering wheel sensor?
