GT2 Slave conversion failure...
Old Sep 20, 2009 | 05:26 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Anybody have one of these go bad. Pedal was getting soft, then it went to the floor and will not come up.No leaks around resevoir or pedal. Tranny dry. Bled per Porsche service manual with a pressure bleeder at 2bar with pedal in the down position.... very little fluid came out. Pulled pedal up and it came out in a hurry.... Pumped half a can thru it and nothing. Internal failure in the slave?
Old Sep 20, 2009 | 09:23 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
No. Kevin...PM sent.
Old Sep 20, 2009 | 10:58 PM
Denver996tt's Avatar
Denver996tt has a spectacular aura aboutDenver996tt has a spectacular aura about
Sounds more like a master cylinder failure to me. Did you use the EVOMS kit for this conversation?
Old Sep 21, 2009 | 04:37 AM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
agree with Master failure.
Bummer.
Old Sep 21, 2009 | 08:32 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
We use the same OEM sourced GT2 Master cylinder with the Tiltons, had 1-2 fail, seems to be a QC problem with the OEM supplier, some others had reported problems at the time I discovered mine had went bad, dealer hadn't heard of such a thing.
keeperofbeasts
11
Apr 3, 2017 10:53 AM
irish100p
Oct 24, 2015 09:37 AM
jaehoppa
Oct 22, 2015 09:17 PM
Yogi911
Sep 9, 2015 08:20 PM
HIX
Sep 9, 2015 04:45 PM
