meth install questions in LA
Old Oct 1, 2009 | 06:26 PM
sc_trojan's Avatar
sc_trojan has a spectacular aura aboutsc_trojan has a spectacular aura about
after reading all these posts, it looks like meth is an inexpensive way to increase hp/tq. besides bbi, has any other shop done a meth install on a 996?
Reading other forums, for a hundred more dollars, it looks like the aquamist system is the way to go.
also, anyone know a cheap source for meth in LA? Due to the hot weather, it doesnt look like we can get the -40 degree windshield washer fluid at walmart.
Old Oct 1, 2009 | 06:39 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I ordered my meth from here by the case, usually
3 cases at a time .. Sometimes they have coupons, and various other discounts, I received a coupon for 15% off in the box with my first order.
Always came quickly (I live in OC). Maybe not the cheapest but reasonble, and very convienent.
http://www.summitracing.com/parts/SNO-40008/
Old Oct 1, 2009 | 07:05 PM
sc_trojan's Avatar
thanks JS. so if I do the math, 4 gallons of 50/50 mix, is 2 gallons of meth for $30, so $15 a gallon?
There is a local race shop in torrance (hot rod performance) that sells 100% meth out of a drum for $6 a gallon.
I was just wondering if anyone found anything cheaper than $6/gallon.
Js- where did you get your unit installed? which meth setup are you running? who did your tune?
Old Oct 1, 2009 | 08:42 PM
JSBear's Avatar
Sounds right, you don't have to mix.
If you can find it for $6 gallon, that sounds like a great deal. I thought most were paying closer to $10 gallon, but I could be wrong.
Just depends if you can find a good source locally, picking up some distilled water and mixing it yourself @ a little of $6 gallon would be real cheap.
Good luck.
COBB Tuning
Jan 1, 2025 09:02 AM
turbotuner20v
Sep 11, 2015 12:02 PM
Aug 21, 2015 09:56 AM
Nissan GTR
Aug 19, 2015 02:11 PM
