Will these narrow body wheels work?
Old Oct 14, 2009 | 06:03 PM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
I found a set of wheel i may want to buy, but they are from a narrow body 911
f: 19x8.5 50et
r: 19x10.5 45et
tia
Old Oct 14, 2009 | 06:11 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Front will fit right, rear with 20-23mm spacer will make it fit. Remember the rear wheel is 1/2" narrower than OEM Turbo wheels. What size of tires are you plan to use? I don't think 315 will fit with 10.5" wheels.
Old Oct 14, 2009 | 07:13 PM
legendr34's Avatar
Thanks for the info Ray, I wanted to use 305/30/19 for the rears, and use a 20-25mm hub centric wheel adapter instead of a spacer...
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 06:34 AM
pwdrhound
Aug 20, 2015 05:54 AM
