Wheel question Gemballa ..
Old Oct 18, 2009 | 07:16 AM
gt2rs's Avatar
gt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of light
Will these wheels fit a 996 2002 GT2 http://www.gemballausa.com/whl_racing.asp
front 9*18 ET +46
rear 11,5*18 ET +33
As i see it the problem could be in the rear but that maybe could be solved with a spacer ?
Thanx in advance for your input
Old Oct 18, 2009 | 10:34 AM
BlueTT's Avatar
BlueTT has a spectacular aura aboutBlueTT has a spectacular aura aboutBlueTT has a spectacular aura about
They will fit just fine depending on your alignment settings. If you have a GT2 I probably would go with the 12" rear to fit the 315 better; however probably not with the et28's. I think they have different offsets if you call them directly. I'm running the Gemballa Racing 19X9 et41 and 19X11.5et27 on my turbo and they fit fine. If I had to do it again I would probably do 11.5et33 in the rear. Incidentally, I just ordered a different set with 18X9.5 and 18X12's for track use. I think there's another thread somewhere where they're fitting 10" fronts.
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
Aug 21, 2015 09:56 AM
