AMS Billet K16's go 133.3mph at the strip
Old Oct 23, 2009 | 09:47 AM
  #31
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
Originally Posted by vbmw335
Lol...this is never ending! Its all good Vince. I know your car is not slow by any means....but just not faster than mine
All joking aside, i know Tony will take good care of you and you will spank me just like you are supposed to.
Talk about a back handed compliment. Nice save at the end just in case I beat your ***.
Old Oct 23, 2009 | 10:08 AM
  #32
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
Lets take this out of AMS thread...i will call you..
Old Oct 23, 2009 | 10:53 AM
  #33
007-911's Avatar
Eric,
How much air are these K16's pushing?
Old Oct 23, 2009 | 12:02 PM
  #34
Prche951's Avatar
that is dam fast. Is this the fastest K16 hybrid trap speed? Definite 10 second car if you can get a 1.7-1.8 60ft time. Did you figure out what is wrong with the clutch? is it just going out?
Old Oct 23, 2009 | 05:01 PM
  #35
vbmw335's Avatar
How much boost were you running?
Old Oct 23, 2009 | 08:05 PM
  #36
rafiki's Avatar
rafiki is infamous around these parts
Originally Posted by Steve Theodore
Eric,
Could you elaborate (at the time of press release) how these differ from the tried and true K16-16G upgrades? ........ Again, I realize the potential is higher with these new AMS billet K16's, just want to know a bit more about the "why". Thanks!
what he said...
Old Oct 24, 2009 | 06:30 AM
  #37
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I have plenty of time on the track. I took out just about everything that was not bolted in. Still only managed a best time of 11.5@128 with a 2.19 60'.
Tony supposedly through out my k16's or I might have done this mod and got rid of the Gt28's. I am going to take the car to AMS on the third of November and let them and EPL tune the car together. If they can figure things out great, if not, then im going to be very pissed off.
Everyone seems to think your ok so majority favor.... but I on the same page as you, after that much money spent on a setup I to would like to see more of a performance gain (specally with the time at the track put in).
My K24 car with 100 octane and simple bolt on mods is trapping at 127mph..
Old Oct 26, 2009 | 12:08 PM
  #38
Frank@AMS's Avatar
Frank@AMS is infamous around these parts
Eric,
1.4 bar
Old Oct 26, 2009 | 12:21 PM
  #39
ttboost's Avatar
Originally Posted by Frank@AMS
1.4 bar
Pretty impressive. For our education and without giving away the farm, of course, can you explain why, that up until this post, it was presumed that anything after 1.1-1.2 bar or so, the K16's just made hot air?
Old Oct 26, 2009 | 12:24 PM
  #40
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
cause the compressor wheel has been inlarged and updated to flow more air i would like to know how much they Flow compared to gt28's and others
Old Oct 26, 2009 | 12:28 PM
  #41
ttboost's Avatar
If that's the case, and if it's a bigger compressor wheel is it REALLY a K16? When you enlarge a K24 it becomes an 18G? One of the other ways to enlarge a K16 is to make it a 16G. What are these?
Old Oct 26, 2009 | 04:19 PM
  #42
AMS's Avatar
AMS
AMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond repute
Just so you guys know were I'm coming from, I've been working with turbocharged cars for 10 years, I've tested, datalogged, compared probably 50-75 different turbochargers or combination thereof. I've also been tuning, designing/testing camshafts, and designing engine combinations that have made 700hp/liter.
On the compressor side, the turbocharger takes in air, compresses it and feeds it into the engine. Work is being put into compressing air and depending on the efficiency at certain pressure ratio's (boost level) it will increase the charge temperatures by a certain amount. Higher temperature means less dense air and makes the engine more susceptible to detonation.
Where a 16G compressor wheel may be way out of it's reasonable efficiency range at 1.2 bar of boost, another wheel may be still working efficiently. Depending on wheel designs, some are made for high pressure ratio use (high boost) and some for lower pressure ratio use. There are a lot of variables to this. Higher pressure ratios (high boost) mean an increase in shaft speed, meaning the turbo is spinning faster. Remember this later.
The turbine (exhaust side) drives the compressor wheel. The delta P (pressure differential across the turbine), heat energy, and exhaust mass flow rate all impact how the turbine wheel drives the compressor wheel. With a properly matched compressor wheel upgrade you can achieve higher charge air flowrates with the same shaft speed. meaning you will be flowing more intake side air without the drastic rise in exhaust back pressure. This has to be done carefully because too big a compressor wheel on a small exhaust wheel will at some point cause lag and no increase in power.
Sorry for the long explanation but there is no real quick answer. I could go into way more detail but I don't want to put people to sleep. I guess if i had to make a quick summary, it would go like this....
K16/16G's: You reach a point let's say 1.3 bar and 500whp (just a rough number for reference) and as you increase boost, the compressor wheel is out of it's usable efficiency range and the rise in charge temps climbs rapidly as does shaft speed and exhaust back pressure, all things that don't contribute to more horsepower.
Take that same turbo and modify it in a way that reduces backpressure and keeps the compressor side in it's efficiency range. This could be a larger A/R turbine housing or wheel, or it could be larger more efficient compressor wheel as in our case. Hope this helps!
If anyone has specific questions please ask away.
-Martin Musial
Old Oct 26, 2009 | 04:38 PM
  #43
Frank@AMS's Avatar
These turbos are hybrids. This is why they give the modified turbos hybrid names i.e. K16/16G,K2418G and so on. All of these turbos have three things in common, they still use the factory turbine/hot sides, center sections and compressor housings. They are also all modified in the same aspect: Changing out the cold side compressor wheel and machining the compressor housing for the larger wheel. They still utilize the K16 frame. At this point, its efficiency goes down to what Martin was saying:
"With a properly matched compressor wheel upgrade you can achieve higher charge air flowrates with the same shaft speed. meaning you will be flowing more intake side air without the drastic rise in exhaust back pressure. This has to be done carefully because too big a compressor wheel on a small exhaust wheel will at some point cause lag and no increase in power."
Old Oct 26, 2009 | 04:43 PM
  #44
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
^To add, the billet wheels have extended tip technology, longer blades for a given diameter (the blades extend further into the hub of the compressor due to material strength and machining process) and they're presumably lighter than a standard 16g compressor wheel upgrade. All of this allows them to continue shining (maintaining efficiency) as the pressure ratio and mass flow goes up.
ttboost,
You're right its not a straight K16 but you could call it a K16/billet 46mm or something along those lines to keep in line with the K16/16g or K24/18g nomenclature.
Old Oct 26, 2009 | 04:53 PM
  #45
rafiki's Avatar
Originally Posted by AMS
.....If anyone has specific questions please ask away. -Martin Musial
Martin, thanks for the explanation.How does one adjust between pump and race gas boost settings?
