DIY transmission mount
Old May 6, 2010 | 10:52 AM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Originally Posted by Erik@GBox
I can make you a solid mount made of delron, cost would be about $100.00 or so plus shipping, but it would certainly be a lot easier than the solutions that I have seen here.
Let me know if I can help,
Erik Johnson
GBox Performance Transaxle
(303) 440-8899 work
how would this be?
Old Jan 14, 2011 | 11:58 AM
PasPar2's Avatar
PasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to all
Have a code for one of these if anyone needs.
Old Jun 26, 2011 | 07:25 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
So, I'm interested in trying out this delrin mount Erik. I have a spare mount. Could I send it to you for you to install the pads?
Thanks,
V
Old Jun 27, 2011 | 11:12 AM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
what do you mean by a code?
Old Aug 19, 2011 | 01:59 PM
kennyPride's Avatar
kennyPride is a jewel in the roughkennyPride is a jewel in the roughkennyPride is a jewel in the rough
Adam-Tip Trans Mount_Window Weld or OEM part_Which one?
Adam,
I was hoping to get your view or anyone else that has tried the repair (window weld) vs replacement with OEM. Is the repair holding up (durability), any vibration issues or alignment issues (trans to motor to drive line..)?
Bottom line which way would you go if you had to do it all over again.
thanks kenny
Old Aug 22, 2011 | 09:11 AM
split's Avatar
i just replaced mine with the new 997 part number and i'm glad i didnt attempt to repair it. When i took out the original, it literally broke into 3 pieces. The new one solved my clunking issue and there's also less vibration in the cabin now.
Old Aug 22, 2011 | 11:00 AM
kennyPride's Avatar
Thanks, Split. I will go the same route. How was the diy? Anything I should be aware of or a little tricky? Did you need to support or lower the trans or was this simply a bolt off bolt on R&R. kenny
Old Aug 22, 2011 | 01:58 PM
split's Avatar
i didnt DIY, i had my indy do it. he was done in 90 minutes and had no troubles.
Old Aug 3, 2016 | 04:37 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
This is a NA 996 mount. Turbos and GTs are different mounts.
jaehoppa
Oct 22, 2015 09:17 PM
the5
Oct 14, 2015 06:46 AM
