Spark plugs question
Old Oct 30, 2009 | 10:47 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Guys I am up for a major service. My car is a XP50 running 1.3 (peak) boost with Cargraphic exhausts. I am at 80K miles; spark plugs were changed at 40K when car was tuned. Do I replace with stock plugs or are any other plugs needed due to tuning? I don’t know what the tuners have put in so I am stuck until car is in a garage. Also, it will be difficult to source whatever plugs might be in there quickly due to my location - Slovenia. What do you recommend? Should I also replace ignition coils whilst in there or leave them be if they seem ok and are taken out with care? Car otherwise runs without missing a beat engine wise. Thanks.
Old Oct 30, 2009 | 11:14 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
so your at 60k now? coils have been a recommended upgrade since you have them out doing spark plugs not a large expense some say dont fix it if it aint broke but other spend the 300$ for new coils while the labor is being done. also check your coolant tanks and clutch accumulator while its being serviced.
Old Oct 30, 2009 | 12:00 PM
Terminator's Avatar
80K now. Different intervals in Europe. Accumulator changed. What's with the coolant tanks? Tanx.
Old Oct 30, 2009 | 12:06 PM
coolant tend to get hot discolor and then crack n start leaking
id probably do a new serpentine belt if i was tearing stuff apart at 80k miles
at 80k if it was my car id do plugs/coils belt, inspect everything else check engine and transmission mounts wheel bearings front diff condition change oil.
Old Oct 30, 2009 | 12:07 PM
John@SpeedTech's Avatar
You are overdue for a plug change. I would change them now. IMO, if the coils are fine - leave them alone.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Highlander
Aug 23, 2015 09:05 PM
