/// EVOMS [S-351] 1000 HP Monster Build Begins - Project Name to be Determined \\\
#121
vacuum side leak through the turbo inlet area from oversized clamp that would not tighten onto compressor. on both sides.
Mike, I am going to do a full pressure test of the entire engine from intake all the way to exhaust. I don't want anything amiss when I turn up the boost. Have you done that yet?
#122
Also got to look at where the power band is. two 700 whp cars that operate in different power ranges will put different stress on the motors. A smaller turbo like a GT30 may actually put more stress on the rods since it is making more torque low in the rpm range which is abusive. Still, how can anyone argue with the need for beefing up internals at 700 whp mark. I think there are enough examples out there by now.
#123
Frankly, 650WHP n the street is enough to pin you to the seat and run down most cars. Push 700WHP and you have to worry more about driveline and building a transaxle in these is about as much "fun" as a motor it seems. If I were hitting 700WHP I'd be pretty happy so long as it was a safe tune and not ripping parts to pieces. In my Supra that was good enough to roast the tires at 70MPH and it was QUITE exciting! For now, a low 600 will keep me most happy and that's not too hard to obtain with 3.6liters!
#126
What build? There is no more build. There never was. It was just smoke in mirrors.
J/K. Things are moving right along. Next week we should have a good portion of the machine work completed. Since this is a "winter project" we had to move some other projects along faster than WT's ghetto build. I will post some more pics soon
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
#128
It did. These things take a while.
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
#133
Didnt even stop by...Im hurt! Just you and your BFF "the Woodster". I would think you would stop and pick up a more qualified driver of high powered GT2s like myself.
#134
Marty came over and helped squeeze the GT2 out of the trailer. It was a very tight fit.
We took it for a quick spin - then I put it in the garage and headed off with the wife.
I'll come by in the next day or two.
