Safety Features under 550-600hp tuning.
Old Oct 31, 2009 | 05:54 PM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
I am installing A28 turbo/injectors/tune. Anyone familiars with safety features under 550-600hp tuning? If oil pump stops and we loose engine. It is understandable. But what about under these condition:
1. Fuel pump suddenly dead or clogged or flow less than normal.
2. Boost control malfunction. Boost go 1.7 barr on 93 pump.
3.Go to bad gas station and got crappy 89 oct while paid 93oct.
4. etc.
What will happen? Check engine light, safty mode or ka-boom.
(What is the different if these happen under stock ecu?)
Old Oct 31, 2009 | 05:59 PM
ttboost's Avatar
Are you asking if any of us has a crystal ball?
Old Oct 31, 2009 | 06:07 PM
aroonkl's Avatar
I mean under any single condition of above. It is common failure and could happen to anyone. Anyone with experience?
Old Oct 31, 2009 | 06:08 PM
Turbo Fanatic's Avatar
As long as the factory 1.4 BAR boost limiter in the ECU is not removed and you are under ECU boost control you should be fine. The car should close the throttle and back off timing when it sees issues, throw a code and go into limp mode.
But you are pushing the limits and there are no guarantees.
Look at my dyno graph below. The car was seeing knocking and high IATs and pulling timing hard. Once it was dialed in (less aggressive) it made a LOT more power. As is, it needs ICs see how it's pulling timing in "steps"?
Old Oct 31, 2009 | 07:26 PM
BLKMGK's Avatar
Yup, fly by wire throttlebody starts to close up when an overboost is detected. You've also got knock sensing looking after timing although I do NOT like to lean on that ever in any car. If your pump goes away the car will increase injector duty but after a certain point you go lean, probably knock, maybe torch a piston. Best case the pump just dies and there's no fuel - no fuel no run and even if at full chat it ought to simply stop without damage - the RaceLogic traction control cuts fuel like this for traction control.
From what I can tell most of the tuners don't just ***** nilly kill off safeties - that sure wouldn't be in their best interest! I know my boost limit is in place for my throttlebody...
Texas1
Sep 20, 2015 09:12 AM
cordsig79
Cayenne 955/957
Sep 10, 2015 03:12 PM
ECS Tuning - VW
Sep 8, 2015 08:29 AM
