Final numbers for the Boost Logic 1000hp+ kit
Well I needed to get around to posting this in its own thread with the graph and impressions from it. The last two days have been really hectic with finishing the car up, getting home, and catching up on sleep.
On to the good part. The kit itself is finally done and omg it was worth the time and money spent! The car is a absolute beast! On the way out of Austin I got to do one roll on before the boost controller finally died (the wire from my old HKS EVC VI finally broke, but a new one will be here this week). I hit it in 2nd gear from 40mph and it literally white smoked all 4 tires while it began to switch lanes on it's own without my control. Unlike most people I had a very unmollested car so my vicious coupler still works PERFECT, so when you manage to blow all 4 tires off it is an amazing feeling. I knew it spun REALLY bad, but my brother calls me from the Yukon and goes "holy **** dude... you literally just white smoked all four tires...". As far as dyno numbers go, I think I finally took the record for the highest dyno stock bottom end car. The temp outside was in the 70s again, the timing is low (it's still a tiny bit lower than a normal pump tune, but I'm not going to change this because I want to be safe) and the car is still rich (again I'm not going to change this because I want to be as safe as I can). I made 3 dyno pulls at 27-28psi (This being the PEAK the EBC saw, in actuality it was at ~26psi during the run) and it made 830+rwhp everytime. It made from 757rwtq-790rwtq (on the last pull). Here is the graph of the best run HP wise! http://pics.skinnywhiteduderacing.com/dynofinal.jpg These numbers are SAE with Smoothing on 0. It was also done vs RPM instead of speed. STD vs speed it made 863rwhp. I know there is a lot of talk about the life of the stock bottom end and I do agree that I am probably sitting on a time bomb, but you have to realize that the car is not run on the boost levels 24/7. I usually run with the EBC off ~13.5psi which makes 554rwhp SAE. I will be tuning for low boost soon (21psi) which will be pump gas + meth and I think it made right at 700rwhp on those numbers. These motors have come a long way from the 600hp is the breaking point barrier. This is the same thing that the Supra guys had been told years ago. Tuning is VERY key at these HP numbers. Some tuners like to turn up timing to make there power on lower amounts of boost, but Justin N and Tony @ EPL thought for my setup the smartest idea would be to keep the timing LOW and the fuel rich just to make sure the heads stay on the car. This not saying they may not blow, but it has a lot better chance not to with little timing in the car. Justin and Tony both explained to me the advantages of this. I'd like to give a HUGE thank you Zohair, Marc, Russel, George, and Chad from Boost Logic for putting the car together. Then I'd like to give a HUGE thank you to Tony @ EPL for taking care of me on the tuning side and dealing with my questions 24/7. Lastly another HUGE thank you to Justin Nenni from Tuning Concepts for putting me with Boost Logic and helping take care of my baby the hole way through out its build. Between him and Tony @ EPL I don't think you can find a combo of tuners with more knowledge than those two. Hopefully when my EVC VI cable shows up we will have some cooler weather so I can go get some 60-130's and track numbers for everyone... Mainly because we all know that dyno numbers don't mean squat! ;) |
Those are awesome numbers...Now go have some fun & be careful. With great power comes great responsibility. :D
Chris - I am seriously, seriously impressed by the power your car is making. Unless someone else pulls a rabbit out of a hat, I honestly believe you will set the records for both 60-130 and Trap Speed for a stock bottom-end 996!
chris , bad a$$ numbers brother .... congrats .
Originally Posted by topgun
(Post 2603170)
Scott I hope to have those numbers soon. I am going to try out things AWD first (at least 60-130) because with taxes coming up I can't afford to go throw my money to Steve @ SJM to build my 17" rear Bogarts just yet. Well I could but the government men may start looking for me and NOBODY wants that! LOL!!! When I do get my drag tires though god help me on my quest for numbers ;) I don't really care to much about ET at the moment since I have stock axles/diff/etc.. but a MPH shows true power at least. |
That is some incredible power
That is one serious setup! Congratulations to all involved. :cool:
What happened between 6K and 7K? Power seemed to taper off and then come back some. Are you comfortable revving that high? Some pretty serious power though, congrats!
Great numbers, Chris. Smoked all four, that's nuts!
Chris, have you lost your mind? Don't you realize you cannot, under any circumstances, quote flywheel numbers? I warned you bro, the crank hp Police are going to bring you in. I think officer Jitsu is coming after you!!
Congrats on the kit...enjoy it! |
Originally Posted by BLKMGK
(Post 2603304)
As far as RPMs I feel pretty comfortable doing it on the dyno and I've used it many of times on the street on my past setup (I've been reving to 7500 for almost a year now) so I'm some what comfortable shifting that high. On the HIGH HIGH amount of power I'm going to try to stay out of that zone with a 27" tire when I get my Bogarts ordered. Kevin, I almost fell out of my chair just now! It's going to be like the final stand off of Bonny and Clyde when that war begins. I'll be firing everything I have in defense ;) LOL! |
Booooooooooooooooooost!!!!!!
Very impressive numbers on stock bottom end Chris, Congrats!!!! I should not say this to you but be careful:)
Crazy numbers....you consider 21 lbs low boost? Personally I would run this set up on 1, 1.1 bars max 99% of the time and keep the revs under 7k. I bet if you do the car will last a long time.
And it should still make crazy power at those levels. What whp do you extrapolate at 1.1 bars? |
Originally Posted by Dr_jitsu
(Post 2603418)
