Does anyone use Redline MT90 transmission fluid ?
Old Dec 6, 2004 | 08:55 AM
RufMD's Avatar
RufMD is just really niceRufMD is just really niceRufMD is just really niceRufMD is just really nice
Anyone have any opinions on the best gearbox oil to use on a 996TT ?
Thanks in advance...
Old Dec 6, 2004 | 09:00 PM
FineProperty's Avatar
FineProperty is infamous around these parts
I used the redline in my long gone 5sp Passat. And, there wasn't a huge difference over stock. I did shift a little more smoothly, but the notchiness was still there.
Old Dec 6, 2004 | 09:04 PM
cjv's Avatar
cjv
Moderator
Swepco.
Old Dec 7, 2004 | 01:03 AM
RufMD's Avatar
Chad, are you using the Swepco 201 or the heavier 210 oil ?
Did you have any concerns that this is a natural product vs the newer synthetic stuff ?
Swepco appears to have quite a following amongst Porsche owners and forums.....why did you pick it ?
thanks in advance
Old Dec 7, 2004 | 05:41 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
If warranty is a concern, I would only used Porsche approved ATF. Chad is not concerned about warranties with his car for obvious reasons...just my 2 cents.
Old Dec 7, 2004 | 08:33 AM
ebaker's Avatar
ebaker is infamous around these parts
You need enough extreme pressure additives to protect the ring and pinion. If the oil has too much additive the syncros don't work well. Some additives can corrode brass. It might be best to use the OEM fluid. I have heard of a lot of people with older Porsches using a mix of the standard weight and the thin Redline GL4 fluids.
Rguy
Apr 12, 2020 11:11 PM
jaehoppa
Oct 22, 2015 09:17 PM
the5
Oct 14, 2015 06:46 AM
