996 Turbo Alarm errors
Old Dec 12, 2009 | 10:47 AM
dominik...'s Avatar
dominik... is infamous around these parts
Hi,
I need advice according alarm error.
Suddenly battery inside key down, I replaced battery for new but key stopped work.
In Durametric I found two error:
60 Central locking limit position
54 Radio receiver defective
I try to find solution but without resoults. Before I go to delear
I would like ask any advice?
Old Dec 12, 2009 | 11:02 AM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
If you get the newest durametric software I've noticed that it explains a lot of the security problems.
Also if you can get the the trouble code porsche numbers I can get you troubleshooting instructions.
Old Dec 12, 2009 | 12:00 PM
TURBO ELECTRO's Avatar
TURBO ELECTRO is a jewel in the roughTURBO ELECTRO is a jewel in the roughTURBO ELECTRO is a jewel in the rough
It is dificult to fully understand you but it seems that you have an aftermarket radio installed and the factory security contact switch is not unpluged and taped off (located on the left side of the radio cavity....it is a female push on terminal....please uplug and tape off......only if I have understude your radio security fault code correcty.
Old Dec 12, 2009 | 12:34 PM
dominik...'s Avatar
sorry mayby I did`t clarify enough.
In have complete stock alarm system.
I replaced battery into the key and after replaced battery the key was stopped work.
In durametric I found two error.
Interesting, I download 6.0 Beta and no fault found in alarm
But previous version found two faults.
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:45 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
