Found a great Ipod solution for pre-MOST
my iphone 3G won't charge. found new solution!!
I do not have the iwire solution but a pie solution working until i got the new iPhone (3G). When i connected the iphone the pie a warning message on iphone screen stating the iphone will not charge. But not only that, i could not get it to play (the iphone built-in speaker would play). Somewhere i read that the iPhone (and other ipods) charge on 5V USB and the pie cable charges 12V Firewire and i should try scosche adapter ($29.95) .
Anyway after some more research i went back to the vendor from which i purchased the pie solution and found a new solution called the Blau/8-din , which can be used with 3 other cables. I opted for the dock connector which they state will play and charge the 3G and older iPods. I emailed the company and was assured it would work with my iPhone and the CD-R220 radio.
I placed the order and two days later the parts were in my mailbox. Waited until the weekend and installed this thing in less than 15 minutes (i already had some experience removing the radio). This works. When i plug in my iphone the airplane warning message comes up, hit "NO" and the music plays loud and clear and the iphone charges. Another cool feature is that if i get a call the music will mute and resume play after the call has ended.
This cable also played/charged my ipod photo (60G).
caution:
The instructions says to connect the black wire to +12V on pin 5 (amp turn-on or something like that). I already tapped into a 12V ignition for the pie solution so i used that. At first everything worked, but as soon as crank the engine the iphone would stop charging and the warning message appears on the screen.
Turn the engine off and charging resume. Figured i should follow the instructions and moved the black wire to pin 5 (amp turn on) and that solved the problem. I emailed discount car stereo about this and was told that the cable is "voltage sensitive" and with the car running the ignition wire changes from 12 to 14.4V, but the voltage on the amp turn on wire remains @ +12V. I doubled checked with a voltmeter and that proved to be true. So there you have it. If you opt for this solution make sure to connect the black wire to the amp or antenna turn on wire (they included a blue t-tap).
By the way, i have the pie solution for sale -- works with any ipod that charges on the firewire pins (12V).
12/10 Update.-- I'm told that a modification has been made so that the +12V charging wire can now be connected on any 12V supply including pin 7, pin 4 or pin 5
caution:
Turn the engine off and charging resume. Figured i should follow the instructions and moved the black wire to pin 5 (amp turn on) and that solved the problem. I emailed discount car stereo about this and was told that the cable is "voltage sensitive" and with the car running the ignition wire changes from 12 to 14.4V, but the voltage on the amp turn on wire remains @ +12V. I doubled checked with a voltmeter and that proved to be true. So there you have it. If you opt for this solution make sure to connect the black wire to the amp or antenna turn on wire (they included a blue t-tap).By the way, i have the pie solution for sale -- works with any ipod that charges on the firewire pins (12V).
Finally installed the iWireP I got from Hogapalooza (thanks) and with the AUX on/off instructions that pvanosta posted it was an easy DIY. Did the GDO and alum dash strips at the same time. Thank gawd for search!
Mine works with PCM1 but you have to keep one of the CD changer plugs plugged ina nd you have to have CDs in the changer. WTF? It works with my 3G iphone too. Anyone else have this?
caution:
caution:
http://www.discountcarstereo.com/detail.aspx?ID=993
http://www.discountcarstereo.com/detail.aspx?ID=1401
Do i need them both ?
Thanks for the great write-up
// André
Ok, I'll admit, I'm technologically challenged so please bear with me......I have an PCM1 (2002) and an iPhone 4. What do I need to buy to play my iPhone music through my NAV/radio? (ps, I have no CD player). Please also let me know if: A. this will charge my iPhone and B. What control/display will I have on my PCM1?
Thanks!
Michael
Thanks!
Michael
iWire
I too have called iWire at least a dozen times and left messages with NOT one return phone call.
You have any luck ?
JIM in Texasto a rep or did you order it directly off the site?[/quote]
You have any luck ?
I just got an email from him yesterday guys. He has been swamped with school; he is finishing up his Masters. Anyway, he sent me an email saying he would have mine shipped out soon and this morning I got an email confirmation from Paypal letting me know that my iWire is on the way. Email is the best way to reach him; just be persistent.
And fyi, I ordered mine directly off the site.
